|  | Home > Puma (Tdci) > Suspension lift. Light version |
| Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216      | I'm waiting for Scola shocks standard height because my garage is low and 110 passes barely so.
 I'm looking for rear spring a bit more strong, do you know the Rate (lbs./In.) of the original springs? Matteo Defender 110 Td4 SE MY 09 | ||
|  4th Nov 2009 3:15pm |
| jamesbond007 Member Since: 28 Oct 2009 Location: Central Algarve - Portugal Posts: 172      |
 I have sent them 2 emails (yesterday and today). No response  | ||
|  4th Nov 2009 6:56pm |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512      | well, sometimes happens Puma 110" SW
 ............................................................. Earth first. Other planets later | ||
|  4th Nov 2009 8:36pm |
| jamesbond007 Member Since: 28 Oct 2009 Location: Central Algarve - Portugal Posts: 172      | Well, I did get a reply early this am.
 I'll do 1 1/2 in front and 1 rear. | ||
|  5th Nov 2009 8:18am |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512      | A word of caution: I`m not sure if you will get issues with your front propshaft going over 1". I lifted 2.5" and I decided to fit a DC propshaft right away. Also for safety reasons. In your case I would fit the spacers and see what happens. Puma 110" SW
|  5th Nov 2009 8:49am |
| Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166      | I feel sure you will get prop/drive shaft issues. Puma's dont like to be lifted. Try the spacers its a cheap option.
 Allan | ||
|  5th Nov 2009 11:45pm |
| jamesbond007 Member Since: 28 Oct 2009 Location: Central Algarve - Portugal Posts: 172      | I am now doing 1 inch all round. | ||
|  6th Nov 2009 8:45am |
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626      | I've got the Bilstein shocks and the H/D Bearmach blue springs on and its give me a 1in lift and an Excellent ride with no issues    NEVER TAKE LIFE SERIOUSLY.                         NOBODY GETS OUT ALIVE ANYWAY | ||
|  6th Nov 2009 5:38pm |
| tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129    |
 Hi 007, I am thinking of doing the same thing too. Can you give us an update of what happened? Did you end up getting DC propshaft after the 1 inch lift? THanks Martin | ||
|  22nd May 2015 3:37am |
| MalteseRover Member Since: 02 Jul 2013 Location: Gozo Posts: 137    | Hello,
 When i got my 2003 110 3years ago, previous owner added a 1" spacer under the front springs. are 1" lifts considered mild and within safe zones? Not causing complications to steering/suspension/toe in/castor angle interference? I have been experiencing death wobble recently since summer 2020. Panhard bush changed twice now  Could this be linked? joseph | ||
|  8th Jan 2021 10:59pm |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327    | Generally, a 1 inch lift would be considered mild and not require any further mods. Your recent 'death wobble' is more likely to be connected to swivel pre-loads, particularly as the lift has been in place for so long. Darren
 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia | ||
|  9th Jan 2021 12:01am |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491      | 35mm was the perceived max lift fit a puma without upsetting prop angles. Engine to t box angles are different in puma to other engine/gbox variants. Cheers
 James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop | ||
|  9th Jan 2021 8:16am |
| camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3418    | I'm running a 50mm lift using Glyn lewis spacers and original springs and shocks.  No propshaft issues.
   Click image to enlarge | ||
|  9th Jan 2021 9:07am |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327    | Josephs 110 is a 2003 model, so pre-Puma. Darren
|  9th Jan 2021 9:50am |
| Posting Rules
