![]() | Home > Puma (Tdci) > Suspension lift. Light version |
| Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216
I'm waiting for Scola shocks standard height because my garage is low and 110 passes barely so.
I'm looking for rear spring a bit more strong, do you know the Rate (lbs./In.) of the original springs? Matteo Defender 110 Td4 SE MY 09 |
| jamesbond007 Member Since: 28 Oct 2009 Location: Central Algarve - Portugal Posts: 172
I have sent them 2 emails (yesterday and today). No response |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512
well, sometimes happens Puma 110" SW
Well, I did get a reply early this am.
I'll do 1 1/2 in front and 1 rear. |
A word of caution: I`m not sure if you will get issues with your front propshaft going over 1". I lifted 2.5" and I decided to fit a DC propshaft right away. Also for safety reasons. In your case I would fit the spacers and see what happens. Puma 110" SW
| Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166
I feel sure you will get prop/drive shaft issues. Puma's dont like to be lifted. Try the spacers its a cheap option.
Allan |
I am now doing 1 inch all round.
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
I've got the Bilstein shocks and the H/D Bearmach blue springs on and its give me a 1in lift and an Excellent ride with no issues
| tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129
Hi 007, I am thinking of doing the same thing too. Can you give us an update of what happened? Did you end up getting DC propshaft after the 1 inch lift? THanks Martin |
| MalteseRover Member Since: 02 Jul 2013 Location: Gozo Posts: 137
Hello,
When i got my 2003 110 3years ago, previous owner added a 1" spacer under the front springs. are 1" lifts considered mild and within safe zones? Not causing complications to steering/suspension/toe in/castor angle interference? I have been experiencing death wobble recently since summer 2020. Panhard bush changed twice now joseph |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Generally, a 1 inch lift would be considered mild and not require any further mods. Your recent 'death wobble' is more likely to be connected to swivel pre-loads, particularly as the lift has been in place for so long. Darren
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491
35mm was the perceived max lift fit a puma without upsetting prop angles. Engine to t box angles are different in puma to other engine/gbox variants. Cheers
| camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3418
I'm running a 50mm lift using Glyn lewis spacers and original springs and shocks. No propshaft issues.
Click image to enlarge |
Josephs 110 is a 2003 model, so pre-Puma. Darren
| All times are GMT |
