Home > Puma (Tdci) > Decat - is it worth it?
Page 5 of 8 <12345678>
K9F
jst wrote:
will you get increased turbo lag though?
Theory is the turbo will spool up quicker.... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #176929 18th Oct 2012 9:21pm
jst
do you not need resistance to reduce flow to help build pressure to get it spooling?
i can see the benefits of no restrictions at higher flow rates.
i have been toying with the idea of de-cat for a while, in fact have had one on the shelf ready to go for nearly 4 years...... Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #176932 18th Oct 2012 9:26pm
ZeDefender
jst wrote:
how long is a while?
That depends on how long hernia surgery takes to heal Rolling Eyes
Don't imagine I'll be crawling under the exhaust until the dressings come off Laughing
And yes - the conflicting turbo, power and emissions theories is why I'm doing it. There aren't many vehicles you can muck about with so easily and reversibly Thumbs Up Tell someone you love them today because life is short.
Post #176955 18th Oct 2012 10:04pm
How easy / difficult is it to remove the cat anyway? Never tried it myself.. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #176963 18th Oct 2012 10:14pm
K9F
K9F wrote:
landy andy wrote:
You will have to remove the gearbox cross member to get it out tho. Andy
Yes you do! Unless you wish to take drastic action and cut the old exhaust out....the decat pipe can then be manipulated into place without unbolting the gearbox cross member. (I didn't cut mine out but I know a man that did!).
On the Puma the decat being the size of an immersion heater I needed to slightly apply pressure with a jack on the gearbox to give me the extra couple of millimetres room to facilitate the 'cat' removal. Box o' spanners and a couple of hours it should be done whatever method/approach you take. Good luck! Thumbs Up
Post #176973 18th Oct 2012 10:34pm
jst
about 1 week then Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #177019 19th Oct 2012 8:37am
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Looking forward the facts and figures, great project Thumbs Up Darren
Post #177025 19th Oct 2012 8:49am
ZeDefender
jst wrote:
about 1 week then
Would be nice (but perhaps a little optimistic Whistle)
Just checked with our local mechanic who has agreed to check the emissions before and after decat. Normally he would only measure smoke particles for a diesel, but he says CO2, CO and HC shouldn't be a problem. As long as I don't mention the word "decat" he is legally OK. Pity he can't fit it for me but he would be breaking the law. He also can't measure NOx (EGR blanking) at the exhaust but says it might be possible via diagnostics.
Anyone know about this (I haven't noticed on Scangauge II)?
Matt Tell someone you love them today because life is short.
Post #177030 19th Oct 2012 9:17am
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
i think no exhaust values are measured over the onboard system as the exhaust has no lambda sensors, not even 1 in front of the cat.
There are codes for the scangauge to read out these sensors on other cars but not on this ford engine as far as i know.
Really looking forward to your results, drill and hammer are prepared just waiting for your green light
Thumbs Up
Post #177037 19th Oct 2012 9:44am
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
What is the legal position in the UK on decatting?
I must admit that the lag on my TD5 is terrible at times, when starting off uphill I have to wind the turbo up a bit before pulling off or it can stall (The wife stalled on Sutton Bank after a bloke pulled out of a layby round the first bend and took 4 attempts to get rolling Rolling with laughter Rolling with laughter serves her right for taking the micky)
I however like to keep things legal so while a decat sounds good, is it legal? He who dies with the most toys wins Smile
Defender 90 & 110, S1 80", Disco 1, S111 88
LRSOC & CVLRC
Post #177040 19th Oct 2012 9:55am
Glynparry25
James, it is the complete opposite.
Just think how the turbo works- you need to spin the exhaust turbine wheel as easily as possible. The way this works is by pressure differential.
If the exhaust gas is pushing on one side of the wheel at say 25psi at 1000rpm, 50psi at 2000rpm and 100psi at 3000rpm and back pressure from the exhaust is 50psi the turning force on the turbine wheel is -25psi at 1000rpm, 0psi at 2000rpm and 50psi at 3000rpm.......... so turbo will start to spin after 2000rpm.
If the exhaust is 'straight through' and has a back pressure of 5psi, the turning force on the turbine wheel is 20psi at 1000rpm, 45psi at 2000rpm and 95psi at 3000rpm...... turbo will be spinning are ready to go from below 1000rpm
^^These figures are completly random and there are other factors (such as exhaust pressure increasing at different RPMs, compressor wheel resistance etc) but just as an idea to show how a free flow exhaust helps the turbo.
I have straight through 2.5 "ID exhaust all the way from turbo through to back box which is small and high-flow muffler. I am at full boost by 1250RPM and is pulling like a freight train. I can't use full throttle in 1st gear as the rev counter would go from 1000-4000rpm in about 1 second.
Glyn Dog Sheep
Post #177043 19th Oct 2012 10:03am
Caterham
Shocked
1000 - 4000 rpm in 1 second.........I presume you're not taking about the defender but some petrol hotrod Shocked
joking aside if reduced restriction improves spin up on the turbo then I can't wait for my warranty to expire and get rid of CAT.
with the improved low speed spin up of the turbo does the engine need to be re-mapped for any improvement to be realised?
cheers Glyn
Post #177045 19th Oct 2012 10:20am
Naks
Only if you want to dice with GTis Thumbs Up
Seriously though, no. If you de-cat and remove the centre silencer box, you will be more than happy with the added zoom-zoom at lower revs --
Post #177056 19th Oct 2012 10:53am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I kept a center box in mine to try and keep a little back pressure but lost the rear. I find the most benefit is low down however others might disagree. Though I run a standard tune 95% of the time with the tune in it will spin the wheels in 2nd on a damp road if you push the loud peddle hard below 2000rpm.
Post #177059 19th Oct 2012 11:14am
Personally I think the most usable power range would be between 1000RPM and 2500 - 3000RPM above that is only really for a split second. Could also do with a boost in power in 5th and 6th gear always find these gears a little dead.. Although perhaps it's me not using enough revs. ____\We|Will|Win/___
Post #177060 19th Oct 2012 11:29am
