Home > Puma (Tdci) > Water separator
dgardel
Italy
Water separator
See here (aulro), interesting post. Just ordered the bowl, now I need to start the plate. Group buy???
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #174232 9th Oct 2012 12:18am
dgardel
Italy
hopsss Embarassed Embarassed Embarassed
here http://www.defender2.net/forum/topic12864....+separator Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #174233 9th Oct 2012 12:21am
Tim_NZ
Australia
Hi dgardel, the extended bowl makes checking for contamination much easier! Please note you need to modifiy the fuel filter cover also.
Thanks,
Tim
Post #174324 9th Oct 2012 1:27pm
Lorryman100
You don't need to use a plate. I used 1 1/4 inch square tubing welded into a H shape. Drilled out the holes for the chassis mounting points, then drill out the filter housing fixing holes and insert riv nuts to fix the housing onto. Open up the bottom tabs on the housing cover and fabricate an extension to cover the bowl. Once welded and grinded, drill a 1/2 hole in the centre of the extension (to give a visible indication without opening the cover) then spray black, a couple of hours work. Thumbs Up
Post #174335 9th Oct 2012 2:13pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
and for those going direction real cold there are heating spiral versions available to keep your diesel liquid in winter.
if you google "130 on portals" you'll find the build thread on another forum of this marvelous 130 and he is explaining the lot about the filters also.
Smile
edit: found it back http://www.expeditionportal.com/forum/thre...ter+heater
whole thread is worth a read
Post #174338 9th Oct 2012 2:29pm
dgardel
Italy
Thank you Lorryman. Have you same photos? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #174340 9th Oct 2012 2:39pm
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
Also you can get a warning light system to go with this filter
http://www.mwfi.com/Stanadyne_Filter/Fuel_Manager_User_Guide.pdf
I have a racor filter fitted as second one and its picked up water and done a great job
Post #175299 13th Oct 2012 8:41am
mick
I have these on my rib Thumbs Up
Post #175437 13th Oct 2012 7:02pm
Lorryman100
I will need to take some DG, as I had to delete a lot of pics from my photobucket account to make space for a new project that I am working on.
Post #176268 16th Oct 2012 5:06pm
dgardel
Italy
Now I'm so curious...... Whistle Whistle Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #176280 16th Oct 2012 5:59pm
dgardel
Italy
IID Pro MV License
Post #176281 16th Oct 2012 6:01pm
