![]() | Home > Puma (Tdci) > Water separator |
See here (aulro), interesting post. Just ordered the bowl, now I need to start the plate. Group buy???
![]() Click image to enlarge ![]() ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License Last edited by dgardel on 9th Oct 2012 12:25am. Edited 1 time in total |
hopsss
![]() ![]() ![]() here http://www.defender2.net/forum/topic12864....+separator Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
You don't need to use a plate. I used 1 1/4 inch square tubing welded into a H shape. Drilled out the holes for the chassis mounting points, then drill out the filter housing fixing holes and insert riv nuts to fix the housing onto. Open up the bottom tabs on the housing cover and fabricate an extension to cover the bowl. Once welded and grinded, drill a 1/2 hole in the centre of the extension (to give a visible indication without opening the cover) then spray black, a couple of hours work.
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 ![]() ![]() ![]() |
and for those going direction real cold there are heating spiral versions available to keep your diesel liquid in winter.
if you google "130 on portals" you'll find the build thread on another forum of this marvelous 130 and he is explaining the lot about the filters also. ![]() edit: found it back http://www.expeditionportal.com/forum/thre...ter+heater whole thread is worth a read Last edited by tatra805 on 9th Oct 2012 3:04pm. Edited 1 time in total |
Thank you Lorryman. Have you same photos? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
Also you can get a warning light system to go with this filter
http://www.mwfi.com/Stanadyne_Filter/Fuel_Manager_User_Guide.pdf I have a racor filter fitted as second one and its picked up water and done a great job |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I have these on my rib ![]() |
I will need to take some DG, as I had to delete a lot of pics from my photobucket account to make space for a new project that I am working on. |
Now I'm so curious...... ![]() ![]() ![]() IID Pro MV License |
