Home > Technical > What's that button for?
Page 2 of 2 <12
Glynparry25
Hmmmmm, spot light switch, never thought of that- was going to fit an ejector seat Embarassed
http://www.youtube.com/watch?v=SPOFPj8iou8
Dual purpose
Glyn Dog Sheep
Post #172019 30th Sep 2012 12:58pm
ericvv
Wouldn't work on mine.... My sunroof opening is not long enough for that... Rolling Eyes
More importantly, what think, are those two switches (rear fog light switch and aux light switch with the #2) simply interchangeable? You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #172027 30th Sep 2012 1:14pm
Glynparry25
Eric, I just went out and checked on mine and yes they are interchangeable.
I am guessing yours works by turning your lights on and then having to select the front fog light switch, Then when you turn your lights off- they go off and then stay off when you turn the main lights back on untill you press the switch again?
Glyn Dog Sheep
Post #172028 30th Sep 2012 1:25pm
ericvv
Glyn, no it's different.
The two switches (left for the rear fog, right for the front fogs) look the same but work in a different way.
The switch for the rear fog is a push-push type. You can turn it on together with driving lights or high beam, but not with the parking lights only. If you turn the rear fog light on with the driving lights, and return to parking lights, rear fog goes off, and when turning the driving lights back on, it stays off, you have to again push it to turn the rear fog on with the driving lights or high beam. That is the standard LR set-up. This switch when turning it on, comes fully back to its rest position, only way to tell that the rear fog is on is by the orange light in the switch and on the dash.
The front fogs switch which is optically the same is working differently, a push latch on - push unlatch off type. You can turn it on and the switch will latch on, and the front fogs will then stay on with either parking lights, or with driving lights. However front fogs will turn automatically off when switching from driving lights to high beam, and reverse again. When you turn this switch on it will latch into a 3 mm deeper position. When unlatched it comes back to level position with the other switches.
So I can independently from the rear fog, turn the front fogs on with either parking or driving lights, but not with the high beam. And I can turn on the rear fog only with the driving lights or high beam, or with both the driving lights and the front fogs illuminated simultaneously.
I think that is the correct legal way of wiring them.
And as both the here discussed aux switch with the #2 printed on it (as in dgardel picture), and the switch for my front fogs are of the push latch on - push latch off type, presume they are indeed interchangeable. HOPE SO Exclamation Whistle
Hope I was clear with how I described it. Confused
Post #172033 30th Sep 2012 2:06pm
Glynparry25
Your front fog switch sounds IDENTICAL to the switch with the 2 on it other than the actual symbol.
The one with a 2 on it (as I have) has the same function as yours latch on or off..... but I have it for spots so works on main beam apposed to dipped (but that is wiring not switch).
The actual plug behind the one with a 2 on it is identical to the rear fog light plug.
Glyn Dog Sheep
Post #172039 30th Sep 2012 2:19pm
ericvv
Post #172040 30th Sep 2012 2:20pm
grafty99
you can change over the switch fronts and leave the main body alone 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #172124 30th Sep 2012 6:45pm
ericvv
Post #172149 30th Sep 2012 7:18pm
bob neville
Yes Thumbs Up
Changed the switch fronts when I put the work light on the 110, fiddly but can be done. Biggest problem will be getting the different switch front, not sure you can get them on their own.
2013 Defender 90 CSW - sold
Post #172154 30th Sep 2012 7:39pm
Killer90
Site Sponsor
Re: What's that button for?
AndyS wrote:
In the Defender XS there's a blanked out button, circled here:
Credit for the picture goes to: Killer90
As I understand it, the dashboard was taken from one of the others in the fleet and adapted for the Puma Defender but what was the blanked out button originally for?
just came across this looking for a spotlight switch Laughing nice picture mate Whistle CSK Automotive
www.cskautomotive.co.uk
Post #184431 12th Nov 2012 8:42pm
Hmmm that blue paint in the background looks familiar too. Whistle ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #184440 12th Nov 2012 8:52pm
Killer90
Site Sponsor
poor old td5 Big Cry CSK Automotive
Post #184443 12th Nov 2012 8:57pm
Page 2 of 2 <12
