Home > Technical > What's that button for?
AndyS
In the Defender XS there's a blanked out button, circled here:
Credit for the picture goes to: Killer90
As I understand it, the dashboard was taken from one of the others in the fleet and adapted for the Puma Defender but what was the blanked out button originally for?
Post #171925 29th Sep 2012 11:33pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Symmetry?
Post #171928 29th Sep 2012 11:43pm
ibexman
Self destruct Whistle Whistle
Post #171930 30th Sep 2012 12:20am
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
Isn't it a blank which can be used for additional lights (spot/driving lights).
Post #171931 30th Sep 2012 12:21am
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
Agree. If you look at the dealer fit option; auxillary / driving lamp kit it includes a button which the instructions tell you to fit in that blank.
Post #171935 30th Sep 2012 12:43am
ericvv
Post #171936 30th Sep 2012 4:56am
dgardel
Italy
http://www.defender2.net/forum/topic795.html
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #171953 30th Sep 2012 8:43am
ericvv
Daniele, my dealer used the same switch as standard in the Puma for the rear fog to wire up my front fogs. See below.
The one which you show with the number 2 written in seems more appropriate for front fogs than mine. Would it be a like for like replacement, or is there difference in wiring, etc. Do you have a part number for that switch, so that I eventually can order it, and have it quickly replaced? Tks
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #171964 30th Sep 2012 9:28am
bob neville
Link below Eric Thumbs Up
http://www.dingocroft.co.uk/acatalog/Electrical_Miscellany.html
YUG000540LNF about half way down the page.
2013 Defender 90 CSW - sold
Post #171969 30th Sep 2012 9:44am
ericvv
Post #171970 30th Sep 2012 9:48am
bob neville
It should be the same wiring unless somebody has altered the connections on the original back connector to get the other switch to work.
I am sure somebody will be along to confirm or otherwise Thumbs Up
Post #171973 30th Sep 2012 9:54am
grafty99
Is the front fog light switch a push - push type? Or a push latch on - push unlatch off type? (hope that makes sense) 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #171980 30th Sep 2012 10:11am
boode
England 2003 Defender 90 Td5 HT Rutland Red
Its a push latch on - push latch off
The price of this switch had jumped from Ģ12 to Ģ45 in a year !!
ericvv - why not simple turn the switch over so it points in the other direction - you may need to cut out some groves to allow this
Post #171998 30th Sep 2012 10:53am
dotom
Germany 2016 Defender 90 Puma 2.2 XS CSW Corris Grey
Has anybody thought about fitting an LCD Thermometer into this blanket? So we donīt have to cut holes in the dashboard.
Tom
Post #172005 30th Sep 2012 11:09am
T1G UP
im using that space for my webasto heater on switch
Post #172006 30th Sep 2012 11:09am
