Home > Maintenance & Modifications > Rear Work Lights
Page 1 of 3 123>
GUM97
Rear Work Lights
Has anyone fitted a rear worklight? If so, where is it mounted? Thinking of putting one on mine but not sure where it will look best. An engine to TDi for!
Post #170755 25th Sep 2012 2:08pm
JWL
An ideal place for a worklight is on the upright part of the roof panel to the left of the door and mounted on a swivel mount. The reasoning is that it is up high without being above the height of the vehicle and will shine down as well as illuminate a little of the inside with the door open. Trouble is that if you have a roof rack, most like mine have the access ladder on the nearside so I ended up with mine on the other side. Some put them in the middle either by the rear washer or replacing it. I didn't want to do that as it would hamper loading the rack from the back. Another option is a socket permanently fixed on the back and a wander lead with a light fixed to a clamp so it can be clipped where it is needed
Post #170757 25th Sep 2012 2:22pm
Here's mine, 13.5" AlienXplorer lightbar ...
Post #170758 25th Sep 2012 2:25pm
Eduardo
Here in mine,
As JWL said, mounted at the rear in the roof rack at the left side with a swivel mount. I use a cheap Hella 4.75" worklight that is enough for my needs.
Advantages: No holes made in the roof: all the cables are running through the roof rack and down attached to the RAI and go to the engine bay with a switch in the panel. If you dont have a roof rack a hole should be done Neutral . Also is a good position to load/unload the Defender and to attach the popup camper in the nigth.
Disvantages: In my case were over the roof rack line and I destroyed it in a parking lot Crying or Very sad Now modified to be under the roof rack line Smile and some restrictions to the movement
Cheers Eduardo
Post #170765 25th Sep 2012 2:49pm
Here are mine. Mounted on modified mirror arms so that they can swing out of the way of the rear flap, and also can shine forwards, sideways, etc. Very useful if navigating tricky terrain in the dark when you need to know what's beside you, or towing wide trailers through constricted places.
Lights are LED units connected into what would be the HRW if I had a rear window.
Post #170776 25th Sep 2012 3:29pm
I do believe some also have a hollow bolt design also for cable routing so your mounting bolt for the light can be used for the cable to go through as well. Other than that this has been the ONE thing that has put me off having any. I was really interested in an IPF dual set up at one point but again the cable routing issue put me off. Not an issue if you have a rack or even better a rack and RAI that then gives you more options. IMHO as little holes drilled the better.
http://www.devon4x4.com/index.php?page=sho...;Itemid=14 ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #170792 25th Sep 2012 4:56pm
JWL
I haven't actually drilled any holes in the roof or panelwork, I have a heavy duty Brownchurch rack on my 110 with strengthening bars to ghe body capping front and back. All wires from whatever is up top is threaded through the inch box supports. At the front all pop under the bonnet or through the front door seal. At the back, wires pass behind the back door seal at body capping height as there is a gap in the rib that the door seal fixes to where the window panels meet the tub.
Post #170798 25th Sep 2012 5:27pm
GUM97
Thanks for all the comments, I've certainly been given a few different ideas. I'm still wary of drilling holes in bodywork, and seen as I don't have a roof rack, that's going to be a problem. Confused An engine to TDi for!
Post #170809 25th Sep 2012 6:23pm
GUM - Likewise. This is why I am interested in the hollow bolt designed lights because I wouldn't mind the holes for the lights only but not have to drill holes for the lights and cables which will no doubt leak so a very bad idea indeed that.
Trouble is personally I'm not a fan of LED's and I'd prefer a rectangular unit rather than round. But the fixing and cable routing design is good none the less. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #170810 25th Sep 2012 6:28pm
GUM97
Yeah I prefer the look of the rectangular ones as well. But that's the best cable routing system I've seen so far Confused If only there was a way to combine the two ...... Question An engine to TDi for!
Post #170815 25th Sep 2012 6:46pm
I have thought of this before and found it to be the only solution:
http://www.ebay.co.uk/itm/M10-Threaded-Nip...1693wt_942
The single issue with this is rust because it isn't stainless Sad Other than that would be suitable. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #170816 25th Sep 2012 6:50pm
GUM97
The problem is, there's no bolt heads on them Confused Or am I missing something? An engine to TDi for!
Post #170818 25th Sep 2012 6:54pm
You would have to use two nut's one each side. OR two nuts on each side tighten against body and the against each nut which would keep the fixing tighter. Or another solution would be to us two nyloc nuts each side.
Ideally you'd want washers each side too with a rubber washer too to create a nice seal. Then once the wires are through silicone inside the hollow bolt to seal it. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #170819 25th Sep 2012 6:56pm
GUM97
Yeah that'd work Very Happy I'll look into it a bit more tomorrow. Thanks for the idea Thumbs Up An engine to TDi for!
Post #170827 25th Sep 2012 7:22pm
Your welcome. It's an idea I came up with but never carried though in the end. If you do go ahead let me know how it goes. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #170830 25th Sep 2012 7:37pm
Page 1 of 3 123>
