Home > Maintenance & Modifications > Rear Work Lights
Page 2 of 3 <123>
LR90XS2011
Same arrangement as lots of domestic table lamp fitting so if you are scrapping one of them salvage the bits you need DEFENDER 90 TDCI XS,
Post #170833 25th Sep 2012 7:40pm
That's a good idea too. Providing the size is suitable for the hole in the bracket of the light. My worry would be rusting though. Shame it's not SS
*Edit*
Managed to find zinc plated but not SS but that's better than nothing for corrosion resistance.
http://www.ebay.co.uk/itm/M10-Zinc-Plated-...3014wt_856 _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #170836 25th Sep 2012 7:51pm
Just been looking and found some that I really like IPF816:
Just ignore the Toyota Whistle
They come with a full wiring harness and switch ect. Although the switch can likely be replaced by a more Defender suitable alternative. I'd use a hollow bolt (If possible) and also get some IPF covers to make it look pretty Mr. Green _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #170882 25th Sep 2012 11:01pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
This is mine - purchased from Brendan (aka Leeds). They don't seem to be on his website but am sure he'd help if you give him a call. Mine is a flood version , there are various others in the range from spot to flood.
I went through the same issues regarding running the cables and waterproofing. In the end I sealed the single bolt holding the light on with Sikaflex and used a simple grommet for the wiring. When removing the panels to do the wiring i found numerous holes open to the elements (from new!) so decided the tiny amount of water that may come in through the grommet was probably academic!
Post #170925 26th Sep 2012 9:07am
T1G UP
im not drilling and extra holes in mine!
Post #170929 26th Sep 2012 9:10am
I don't know why there's such a fuss about drilling holes. Making them watertight is the easiest thing in the world and I can't imagine a rear worklight affecting resale value, if that's what you're worried about. Darren
Post #170952 26th Sep 2012 10:25am
For me I'm not worried as such about drilling holes but you must admit that as little holes as possible and the neatest job is a good idea. So if possible to only have one hole for both the light mounting and cable it will be better than having multiple holes drilled out. Especially one just to put a cable through. Yes you can have a hole drilled for both bracket and cables but then it's not as neat... _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #170963 26th Sep 2012 10:45am
grafty99
I don't like the look of worklights so mine is mounted inside facing out of the drivers side quaterlight next to the rear door, shines out of my tinted window no problem Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #170965 26th Sep 2012 10:45am
farmer giles
i did see an extended number plate lamp fitting especially designed for mounting a worklamp on (for softtops, double cabs, etc) in LRO recently.
i will try and find out more details Thumbs Up
Post #170980 26th Sep 2012 12:17pm
T1G UP
now were talking
Post #170987 26th Sep 2012 12:38pm
If you really want a 'no holes' solution then there are various options, although each has a variety of compromises. Mounting inside as already mentioned, is one, although positioning in a USW is more of a challenge. The other downside is that it's difficult to direct the light downwards, at a tow bar for example. Alternatively, you can use a clamp-on CB aerial mount on the rear gutter and run the cable through the door seal, but might have to be careful with the weight of the chosen light. Put a metal plate inside the roof and use a magnetic base, or even make a bracket that picks up on the existing upper door hinge bolts are other possibilities. Darren
Post #170991 26th Sep 2012 12:58pm
mobilecentre
We do some hollow bolt options but you still have a hole
Post #171092 26th Sep 2012 8:06pm
Which one's are the hollow bolt one's? Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #171097 26th Sep 2012 8:13pm
mobilecentre
To be honest we can offer it on most of them as we use a bracket called a fender mount so when you mount on a mudguard on say a tractor you need the cable underneath rather than on top so use a hollow bolt mounting option. I will try to get some pics up.
Post #171099 26th Sep 2012 8:17pm
Thank-you Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #171100 26th Sep 2012 8:18pm
Page 2 of 3 <123>
