Home > My Defender > My 110DC has a new buddy !
Page 5 of 6 <123456>
still away being powder coated ... will get some KM2's or STT's fitted and pop a photo up
Post #169002 17th Sep 2012 9:44pm
bob neville
Got some more done today (no pics) and have finally given up on fitting the SE wheel carrier.
Having now got the correct wheel carrier for the 90 with the correct length arms the thing still does not fit Big Cry
Local body shop modified the bottom body bracket so it would fit correctly - so far so good.
Put the bracket on the door and put the main carrier on to position the top body bracket. After three of us spending a good couple of hours trying to get it to fit we failed.
The door bracket is half an inch to low and to drill the door would mean that new crush tubes are needed etc. The body shop said it would not be a good idea to drill new holes in the door as they would be way too close to the existing mounts and would probably give way. The bracket can't be drilled as the holes are right at the bottom.
We then thought about plating the door but before starting we held the mount in the correct position to at least see if the top body bracket would fit. It would if the centre door hinge was removed Big Cry
It is destined for the skip Rolling with laughter
Fitted all the remaining insulation in the front and started making up new looms for the extra instruments.
Invested in some proper ratchet crimpers from Polevolt, making connections up is now a pleasure Thumbs Up
2013 Defender 90 CSW - sold
Post #169089 18th Sep 2012 6:05pm
SE - steptoe edition ??
Post #169091 18th Sep 2012 6:10pm
bob neville
Might as well be Steve, it would probably fit on a cart Rolling with laughter
Safari Equip. They must have sold hundreds of the things so I (and quite a few others) can't work out why it will not fit on the my TD5.
If it did fit the spare wheel would sit so low that I think it would be useless, the bottom of the tyre would in line with the centre of the rear crossmember and I am guessing the nato hitch would have to be removed.
I can't justify the cost of a full chassis mount version on this vehicle so it looks like the spare will have to stay in the back or I will just have to put the original LR door mount back on.
Post #169092 18th Sep 2012 6:24pm
bob neville
TDS 9.5 winch fitted this afternoon and all plumbed in Thumbs Up
Picking up a Disco transfer box tomorrow so I can have more relaxed cruising.
Post #169952 22nd Sep 2012 5:29pm
bob neville
An update on progress, no pictures - you will find out why later Big Cry
All paintwork sorted and bits bolted back on.
Duff modular wheels replaced by Craddocks and tyres swapped over. First class service from Craddocks Thumbs Up
First Four modified winch bumper fitted and TDS 9.5 winch fitted and plumbed in.
Turbo hoses changed for silicon ones, the old rubber ones were shot.
Mud centre panel fitted to the 2002 type radio housing and clock, volt meter and boost gauge fitted. Boost still not plumbed at the gauge end as myself and the indy, where it currently is, still can't work out how the pressure pipe fits on the back of the VDO gauge.
Given up on the spare wheel carrier, life is to short and I have far better things to do Laughing
Spare wheel is going to live in the back but I wanted the ability to carry something in the back other than a spare wheel.
Solution was found with a lot of help from Peter at First Four, a set of Mantec 110 rear wheel arch cages and shelves - they will fit Thumbs Up Cages will give enough height to allow the spare wheel to live under the shelves and combined with the dog guard will give a good storage/load area. Not seen them yet as Peter delivered them to the indy where the 90 currently is, the intention was to fit them this weekend but ........
Sent the 90 in to have the injector seals changed, the state of the old ones can be seen here
http://defender2.net/forum/topic15669.html
Intention was to collect the 90 tomorrow, fit the cages etc and finish it off.
Then came the email at lunchtime Shocked
They were running the 90 this morning and there was still the smoke problem.
The Indy had some extra mechanics in helping with some other work and they asked their opinion as to what the problem may be - diagnostics showed no problem. One of them was suspicious that it was turbo related and removed the front of the turbo to investigate and all became clear. On revving the engine the turbo was not spooling up correctly, there was a lag of a few seconds. Can't tell you the exact problem but it sounds like the bearings have expired and when the turbo eventually decided to spool it resulted in the blue/grey smoke.
After much debate it was decided to fit a new turbo rather than get the old one fixed - it will be delivered to the indy on Monday.
Expensive bill on the way but I am glad they found the turbo problem, I would not have fancied it expiring in the middle of Salisbury Plain !
There is light at the tunnel and I will post pictures of the finished article when it returns next week Thumbs Up
Going down the pub now whilst I can still afford a pint Rolling with laughter
Post #177202 19th Oct 2012 6:49pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
A broken turbo on a TD5 is the best time to upgrade! Chop it in for a VNT
Post #177210 19th Oct 2012 7:07pm
bob neville
Did think about that but as it is going to be used mainly offroad I am not sure I would get the true benefit.
If the Puma throws its turbo then a VNT is a no brainer Thumbs Up
Post #177212 19th Oct 2012 7:11pm
wslr
Microcat is showing £1200.19 for a brand new Genuine Part unit, Bob. Big Cry Luckily, yours will be much less. Thumbs Up
Post #177306 19th Oct 2012 10:29pm
bob neville
Almost finished Thumbs Up
Centre dash modified with a Mud plate. Clock moved from main console to allow rev counter to be fitted plus volt and boost gauges added.
Mantec cages and shelf added, spare wheel lives under the shelf. Small mods needed to get them to fit - they are for a 110, had to shorten the side cages by about 1.5" to allow them to fit with the dog guard (top is not fitted in the pictures). They will fit into a 90 without a dog guard without any mods.
Front end ready for action Thumbs Up
Post #181681 3rd Nov 2012 5:19pm
v40mav
Looking very good
Well worth the time and effort Thumbs Up Defender 110 County SW
Disco 3 HSE
Freelander 2 HSE - SOLD going back to a car
www.lothian4x4response.org
Post #181688 3rd Nov 2012 5:36pm
hey Bob - you've been really busy - your truck looks ace! coming out to play on the 25th ?
Post #181867 4th Nov 2012 9:29am
Nice lil project, looks well Cool QRZ 2e0vpf
Post #181883 4th Nov 2012 10:04am
bob neville
Thanks Steve Thumbs Up
Not sure about the 25th, my relatives are here from the US until Dec 15th so I am organising things around them at the moment Neutral
Should have plumbed the boost gauge today having got all the correct bits now from a local pneumatic parts supplier but frost bite got me before I could finish Laughing
Post #182087 4th Nov 2012 8:52pm
Green Machine
Looking good now Bob! Although I thought it was quite nice to begin with! It does look a lot more purposeful now though. Storage cages look really neat too and should stop things rattling around when you're in the rough stuff! Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #182100 4th Nov 2012 9:21pm
