Home > Td5 > Diff question.
roel
Diff question.
I have a Detroit locker and a truetrac LSD in RR classic diffs in my 1997 Camel Discovery. They are 24 spline diffs.
Will they be a straight swap to my TD5 90?
I don't have the Camel at home, it is standing in front off the Dutch Camel trophy museum, his new home, so I can't just have a look. Roel
2003 90 Td5 (2009-now)
Post #16895 19th Oct 2009 6:28pm
Yes, they'll fit straight in.
you may be better off getting some HD axle shafts though (like V8 24spline, although the drive hub is bigger with those... a factory disc braked HD shaft isn't listed (if you run alloy wheels then the hub will be too big))
you could always get some from Ashcrofts.
Post #16912 19th Oct 2009 10:05pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Is the 90 on 24 splines Question or is that the 110 Original Member Pie n Pea Club.
110 HCPU Tipper
Post #16920 20th Oct 2009 9:09am
All 90's from late 200Tdi 1992~3 with disc braked rear axles are 24 splined
Post #16933 20th Oct 2009 12:48pm
roel
Thanks guys,
I'll stay with the standard 24 spline shaft for a while. I'll have a look if they are the same as from the Camel as I only broke 2 in 7 years.
I only paid about 35 pounds for each so I probably buy a spare set, so they don't break. Whistle Roel
Post #16952 20th Oct 2009 9:32pm
