![]() | Home > Maintenance & Modifications > 90 rear disc conversion |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
I've done numerous disc braked axle swaps onto 90's, mine and friends.
I've always just fitted the axle and connected the flexi pipe up, and left it at that. never touched any proprtioning valves (some have had them fitted, some earlier models didn't) and they all braked just fine, passed the MoT's, and didn't try to swap ends when you brake hard (the rear pads are quite a lot smaller than the front, and only twin piston per caliper so a lot less braking force compared to the front) |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480 ![]() ![]() ![]() |
i have done about 4 conversions like this and have done the same as Jamie, all work fine as is.
when you say one pipe to the front i take it you mean to each caliper. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Devomorris Member Since: 11 Sep 2012 Location: Borneo jungle Posts: 7 ![]() ![]() ![]() |
Thanks guys , I think I may be over complicating things. Cheers
