Home > Maintenance & Modifications > 90 rear disc conversion
Devomorris
Brunei 1984 Defender 90 V8 Petrol CSW Auto Chawton White
Hi guys, was wondering if there are any brake gurus out there that can help. When strapping on a rear axle from disco 1 to my 84 model 90, which pressure senser should I use. There original is the G load. I had intended to run twin brake pipes to front but have changed my mind and using single instead. I bought a new disco valve but if I install this as in the disco I'll have primary circuit running back and left front with secondary running right front. Is this a good idea? Cheers
Post #167524 11th Sep 2012 12:57am
I've done numerous disc braked axle swaps onto 90's, mine and friends.
I've always just fitted the axle and connected the flexi pipe up, and left it at that. never touched any proprtioning valves (some have had them fitted, some earlier models didn't) and they all braked just fine, passed the MoT's, and didn't try to swap ends when you brake hard (the rear pads are quite a lot smaller than the front, and only twin piston per caliper so a lot less braking force compared to the front)
Post #167536 11th Sep 2012 7:38am
jst
i have done about 4 conversions like this and have done the same as Jamie, all work fine as is.
when you say one pipe to the front i take it you mean to each caliper. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #167622 11th Sep 2012 3:38pm
Devomorris
Thanks guys , I think I may be over complicating things. Cheers
Post #167850 12th Sep 2012 2:45pm
