![]() | Home > Technical > PLEASE HELP |
JOENGELBRECHT Member Since: 21 Aug 2012 Location: CAPE TOWN Posts: 8 ![]() ![]() ![]() |
Hi Everyone please help. I drive a LR 90 Puma Defender 2.4. Recently I have had it in the shop as it revs whilst stationery and then has no power in the pull off in 1st and 2nd gear.
Anyone out there experienced this and if so what was the problem? Thanks Joanna |
power on 3, 4, and more? reverse gear? if not check the shaft from the gearbox to the transfer item 22 (see below) ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Hi
Thanks for your quick response and help. Funny thing is the 1st time this happened no power in 1st and 2nd but when she hit 3rd she was flying. Dealership downloaded software she was fine for another 2 weeks, 2nd time it happened no power in 3rd and 4th? Sorry I am a chick so all this technical stuff a bit over my head so I am trying to get as much information as possible to take to dealerships or somewhere where I feel comfortable that they know what they are doing. I will take the information that you have given me including diagram and share it with the techs that I am working with here. Appreciate your help, have you had the same problem? Regards, Joanna
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
[quote="JOENGELBRECHT"]Hi
mhmmmm ok forgot the shaft (item 22) otherwise no movement on ALL gears. Probably something related to the SW (or to the turbo actuactor). Have you the MIL lights ON (orange engine symbol on dashboard), have you the possibility to read the DTCs (errors code) from the ECU? Daniele Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
I guess if the software worked for a few weeks, then it is likely to be something along the software lines (although you don't always get the true story from a dealership).
[quote="dgardel"]
Hi Daniele There is no lights on the dash everything seems fine. The first dealership fixed the errors apparently with the software download the 2nd dealership reported no errors? The 2nd dealership claims new EGR valve needed? Hope that helps. |
if the cause is the EGR you can see smoke on the exhaust . With the car switched off try to remove the red circled connector and test te Defender. If the defender goes well, the problem IS te EGR valve. ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
H
So the EGR has been blocked off on Monday got car back Wednesday and this morning same thing happening but worse!!!! Error Codes: U0001-88: HIGH SPEED CAN COMMUNICATION BUS P1643-87: CAN LINK ENGINE CONTROL MODULE/TRANSMISSION CONTROL MODULE CIRCUIT NETWORK MALFUNCTION I know I should be patient but seriously I am loosing faith ![]() Does anyone know what or how to fix the above? It is back with the dealer lets see. Regards, Joanna [quote="dgardel"]
