Home > Off Topic > Self leveling screed
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Hi,
Just wondering if anyone has any recommendations for the above. My garage floor is dry and dusty with quite a few rough and worn parts that have depressions, mini potholes etc.
I just want to seal it [PVA?], screed and then paint. I am not after a perfect finish, just a much better finish. I am rubbish at plastering so a self leveling solution sounds good.
Thanks. BM52
Post #164038 23rd Aug 2012 9:11pm
Nick T
England 2010 Defender 90 Puma 2.4 HT Galway Green
For the pot holes use granno. Screed doesn't go far and isn't cheap.
Post #164041 23rd Aug 2012 9:21pm
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
our garage floor was permanaently dusty so i just used the cheapest emulsion paint i could find. it won't solve the pothole problem but it will seal the surface and make it easy to clean. first coat was heavily watered down, second coat was neat.
Post #164063 23rd Aug 2012 9:52pm
leeds
Self levellng compound is not cheap! Consider carefully how rough the floor is and where and how you will be working in your garage. Can you move work bench/storage units over the worst areas?
Thoroughly sweep/vacuum garage. PVA diluted 50/50 with water painted over floor leave for 24 hours. Worst areas where you do not want them try self levelling compound. Floor paint will cover minor defects.
Brendan
Post #164072 23rd Aug 2012 10:37pm
Nick T
You might be as well just to fill the deeper holes. Costo were doing a garage floor covering (bit like lino) weren't a bad price from memory.
Post #164075 23rd Aug 2012 11:11pm
landy andy
Wickes own self levelling is quite good, and the tip for it is to over water it and make the floor wet before applying. If you want a nice garage floor then paint it with 2part apoxy resin, that is what workshops/factories have. Wickes also sell a floor stabiliser, have some but have not yet used.
Andy
Post #164097 24th Aug 2012 7:53am
bm52
Thanks for the replies. The wickes stuff looks good. Just been reading it up. Looks like I will need about 4 bags to skim the back half of the garage and then paint.
Cheers Thumbs Up Thumbs Up BM52
Post #164105 24th Aug 2012 8:58am
Self Level resin we used in the Kennel its great but it does pool in corners so its not fully plug n play Thumbs Up
Post #164112 24th Aug 2012 9:31am
