![]() | Home > Off Topic > Self leveling screed |
Nick T Member Since: 29 May 2011 Location: Bolton Posts: 203 ![]() ![]() ![]() |
For the pot holes use granno. Screed doesn't go far and isn't cheap.
shaun.mobile Member Since: 12 Dec 2011 Location: England Posts: 156 ![]() ![]() ![]() |
our garage floor was permanaently dusty so i just used the cheapest emulsion paint i could find. it won't solve the pothole problem but it will seal the surface and make it easy to clean. first coat was heavily watered down, second coat was neat.
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Self levellng compound is not cheap! Consider carefully how rough the floor is and where and how you will be working in your garage. Can you move work bench/storage units over the worst areas?
Thoroughly sweep/vacuum garage. PVA diluted 50/50 with water painted over floor leave for 24 hours. Worst areas where you do not want them try self levelling compound. Floor paint will cover minor defects. Brendan |
You might be as well just to fill the deeper holes. Costo were doing a garage floor covering (bit like lino) weren't a bad price from memory.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052 ![]() ![]() |
Wickes own self levelling is quite good, and the tip for it is to over water it and make the floor wet before applying. If you want a nice garage floor then paint it with 2part apoxy resin, that is what workshops/factories have. Wickes also sell a floor stabiliser, have some but have not yet used.
Andy |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Thanks for the replies. The wickes stuff looks good. Just been reading it up. Looks like I will need about 4 bags to skim the back half of the garage and then paint.
Cheers ![]() ![]() |
Self Level resin we used in the Kennel its great but it does pool in corners so its not fully plug n play
