![]() | Home > Puma (Tdci) > Realistic fuel tank capacity |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2684 ![]() ![]() ![]() |
It doesn't limp. What will happen is that the engine will hiccup. IIRC then it will switch itself off in a couple of kms to prevent the engine from running out of diesel completely. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Why do I get the impression we don't use our vehicles "normally"?
![]() But shout it at them in German because life is also terrifying and confusing... |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Probably more than we think I reckon, I managed to do 69 miles (to a filling station) in a d3 after the trip (trick) meter said 0.00 miles range on remaining fuel! The garage I was going to go to was blocked off on the motorway and couldn't go elsewhere as we were boxed in in a huge traffic jam. A bit of slipstreaming and hardly any throttle seemed to work (maybe I'll try that in the 110 when I have nothing better to do ![]() DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
T5bnc Member Since: 13 Sep 2012 Location: S.Wales Posts: 40 ![]() ![]() ![]() |
in the words of Robin--- holy thread retrival batman!!!
Ive a 59 110 XS and get 350miles at best when the ping come on!!!!! |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Really? |
david110 Member Since: 11 Dec 2009 Location: Stirlingshire Posts: 81 ![]() ![]() ![]() |
I have a DC 110 and I'm returning 25mpg no matter how you drive, I have had it from new and have been keeping a close eye on the consumption as its been my first new buy ever so was keen to see how things went. According to my phone app I have spent £6,500 on diesel and I get 24p to the mile.... I dont care to much its only out of interest as I could as easly buy a car that did 74mpg but it wouldnt ba a Defender and most probably wouldnt do what I wanted.......... My son also owns one a TD5 defender and my wife drives Discovery 4 so we are an Land rover family.
Happy Defenders all round David |
leealanr Member Since: 18 Mar 2014 Location: Addis Ababa, Ethiopia Posts: 33 ![]() ![]() |
Managed 800 plus kilometers for 101 ltrs in heavy traffic use in Addis. Tank is 120 litres. Darent run the tank to low and use only one source for fuel where possible. Dont want to even think about getting into limp mode outside of the city.
Grey110 Member Since: 20 Jun 2012 Location: Delft Posts: 35 ![]() ![]() |
The WSM says:
Fuel tank usable fuel 90 Models ............................................................... 60.00 13.20 gall 110 & 130 Models ................................................... 75.00 16.50 gall What I understood is that the real fuel tank capacity is 5L more because you should not use the last 5L. That's why it says useable. Martin Martin Previous 2003 Defender 110 Hardtop TD5 2004 Defender 110 Station Wagon TD5 - Libyan Sand 2005 Discovery 3 - V8 - Black |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
I am sure when the Td5 90 was launched the fuel tank capacity was stated as 67 ltrs, not sure about the 110. 2005 Td5 90 XS
Steve |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
If you have a metal tank in a 110 its 80 litres
![]() Plus an extra 2 if you fill it up the neck ![]() |
![]() ![]() ![]() Luckily I am a WSM collector ![]() TD4 2.2 WSM says: Fuel Tank Capacities Variant Capacity (Useable Fuel) 90 55 liters 110/130 70 liters and: LOW FUEL INDICATION AND RUN DRY STRATEGY for 2.2L MY2012 The run-dry strategy is used to maintain the systems fuel prime at fuel run out. It ensures the minimum amount of fuel is always left in the swirl pot. The instrument cluster activates the yellow low fuel warning light (next to the fuel gauge) with 17% of fuel remaining in the tank. The fuel gauge will indicate empty with 12% of fuel left in the tank. With 6 liters left in the tank the run-dry strategy will be invoked. An engine mis-fire will be induced for approximately 1 mile after which the engine will be shut down. The engine can be re-started in mis-fire mode and will continue to run for a further mile until the engine shuts down again. This can be repeated until the fuel suction port in the tank is uncovered and causes engine fuel starvation and loss of prime. Re-starts after run-dry shut down are not recommended. For 2.4L MY2007 it is: LOW FUEL INDICATION AND RUN DRY STRATEGY The run-dry strategy is used to maintain the systems fuel prime at fuel run out. It ensures the minimum amount of fuel is always left in the swirl pot. The instrument cluster activates the yellow low fuel warning light, (next to the fuel gauge) with 15% of fuel remaining in the tank. The fuel gauge will indicate empty with 11% of fuel left in the tank. With 4 liters left in the tank the run-dry strategy will be invoked. An engine mis-fire will be induced for approximately 1 mile after which the engine will be shut down. The engine can be re-started in mis-fire mode and will continue to run for a further mile until the engine shuts down again. This can be repeated until the fuel suction port in the tank is uncovered and causes engine fuel starvation and loss of prime. Re-starts after run-dry shut down are not recommended. Martin Previous 2003 Defender 110 Hardtop TD5 2004 Defender 110 Station Wagon TD5 - Libyan Sand 2005 Discovery 3 - V8 - Black |
