![]() | Home > Puma (Tdci) > Realistic fuel tank capacity |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
wow!
![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2494 ![]() ![]() ![]() |
couples of days after the big earthquake when nearly all fuel station were off duty. Quite scary. Puma 110" SW
80 ![]() ![]() And how much of that gets immediately disposed of then via the tank vent rubber tube ![]() When I fill up, I stop at the first click of the filling nozzle. Afraid if you fill further up to the top of the filler tube, you just are wasting precious gold ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
4x20l jerry cans.....making 80l. Off course the low fuel alarm went off way back. I was sweting.
My small car still can get 6 more liters after the first click (always). Puma 110" SW ............................................................. Earth first. Other planets later |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
It does indeed have a limp mode when there is only 4 litres left in the tank. When your driving, it cuts the engine for about half a second then the engine cuts in again and it keeps doing this every few seconds, i guess until it completely runs out. Luckily i was about 2km away from the petrol station when it happened to me. I put 57l in the 90, then just started it as usual, no pressing the brake pedal whilst twisting the temp knob and standing on one leg and singing ging gang gooly, just twisted the key and it started as usual.
Regards, Mark ![]() |
I think the daft antics are only required after you've killed it entirely - you got to a station and tanked up before that happened (luckily)
![]() Thanks for the confirmation - I am now prepared... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
devnull Member Since: 29 Mar 2010 Location: Poland Posts: 18 ![]() ![]() ![]() |
74 liters between riding 0.5 km in a limp mode (P115A) and a first tick at the gas station
![]() But shout it at them in German because life is also terrifying and confusing... |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2277 ![]() ![]() |
I filled my new 2.2 110 xs right to the top from complete empty and only got 70 litres .
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 ![]() ![]() ![]() |
Today on my way back from Brum, the low fuel indicator bonged at 405 miles, drove another 25 miles and filled her right up to the brim just abouts, it took 68.68 ltrs.
It was at Leicester services on the M1, BP garrage and the normal diesel today was 1.509 a litre, so after the maths £103.64 to gas up ![]() |
put a £101 in the 110 @ 1.39 so thats 72.6L well off the end!
megatoad Member Since: 07 Jan 2012 Location: Hertfordshire Posts: 358 ![]() ![]() ![]() |
I always get nervous when the needle is mid orange, then I usually get 65l to the first click on the pump.
How far below red does the needle go before running out? Also is this limp mode a feature of the TD5 too? I am always nervous of running out of fuel after limping to a petrol station in my old Perkins engined 109, filling up and airlocking the pump as I drove off the forcourt onto the Leeds Ring Road! With the 4203 you had to crack each of the injector pipes while cranking to bleed the pump before it would restart ! |
heinrichnel Member Since: 07 Apr 2010 Location: Windhoek, Namibia Posts: 42 ![]() ![]() ![]() |
This weekend I managed 118 liters into my 110 with an extra fender tanks, I was under the impression the capacity was 120 Lt? Now not so certain. And no limp mode with according to what I know 2 liters left in the tank?
I think you've asked the million pound question there. Can anyone answer: How much useable fuel is left after the "beep"? I can't find it in any LR texts. Knowing that and assuming a pretty poor fuel consumption, you'd know how far can you drive before going limp ![]() But shout it at them in German because life is also terrifying and confusing... |
