Home > Maintenance & Modifications > Safari fitment to a Puma
x-isle
Just thought I'd mention this to see if anyone else had noticed.
I fitted a Safari to the Landy and when it came to sealing the filter box, I actually noticed 2 drain holes rather than the main 1 as listed in the instructions.
The main one is pretty clever in that it catches any water entering the box and then it goes out the drain before entering. The other was the acual box mount at the front of the engine bay. The bit that goes into the rubber mount has a small hole straight through. I'm guessing this is in case water has entered the main filter box and can then drain out. I just put a small screw from the outside.
The more I thought about sealing it all up, the more I got concerned with it all. All the drains are now blocked which is great, but of course, if any water does get through the rest of the sealing it has nowhere to go except into the turbo and blown into the engine............ Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #163196 20th Aug 2012 9:18am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I think that is why Safari state in the instructions that it is up to the owner/installer to decided whether to seal the drain holes. I had the same predicament when I did mine a month or so ago.
Boy
Post #163201 20th Aug 2012 9:26am
familymad
The plan on all Defenders is to seal up all holes on anything and everything Laughing 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #163218 20th Aug 2012 10:25am
jst
seal it all properly and water wont get in therefore no problems. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #163235 20th Aug 2012 11:41am
x-isle
Totally agree, I was just saying........what if....... Craig Rogers
2007 Puma 110 XS
Post #163241 20th Aug 2012 12:08pm
Craig, are you going to be in water that deep? QRZ M8VPF
Post #163242 20th Aug 2012 12:30pm
x-isle
Hope not! Laughing
But if last month is anything to go by.............
It's all about the looks init bruv!.... Whistle Oh and to run cables for the roof lights. Craig Rogers
2007 Puma 110 XS
Post #163243 20th Aug 2012 12:32pm
Looks well Cool
Even though I have a snorkel (as it's dusty around these parts) Wink I wouldn't go into anything that looked dubiously deep anyway.....not with the ecu under the seat ! QRZ M8VPF
Post #163303 20th Aug 2012 6:47pm
x-isle
I was thinking about sealing the doors shut as I don't want wet feet...... Craig Rogers
2007 Puma 110 XS
Post #163304 20th Aug 2012 6:50pm
Cut your feet off... You'd save a fortune on socks and shoes Thumbs Up QRZ M8VPF
Post #163305 20th Aug 2012 6:51pm
x-isle
Didn't think about that.......hmm.
FOR SALE: Defender Puma pedal assembly. No longer required. Craig Rogers
2007 Puma 110 XS
Post #163310 20th Aug 2012 6:57pm
Rolling with laughter QRZ M8VPF
Post #163317 20th Aug 2012 7:20pm
