![]() | Home > Maintenance & Modifications > Safari fitment to a Puma |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
Just thought I'd mention this to see if anyone else had noticed.
I fitted a Safari to the Landy and when it came to sealing the filter box, I actually noticed 2 drain holes rather than the main 1 as listed in the instructions. The main one is pretty clever in that it catches any water entering the box and then it goes out the drain before entering. The other was the acual box mount at the front of the engine bay. The bit that goes into the rubber mount has a small hole straight through. I'm guessing this is in case water has entered the main filter box and can then drain out. I just put a small screw from the outside. The more I thought about sealing it all up, the more I got concerned with it all. All the drains are now blocked which is great, but of course, if any water does get through the rest of the sealing it has nowhere to go except into the turbo and blown into the engine............ Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3502 ![]() ![]() ![]() |
The plan on all Defenders is to seal up all holes on anything and everything
![]() 1995 110 300TDI 1995 90 300TDI |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480 ![]() ![]() ![]() |
seal it all properly and water wont get in therefore no problems. Cheers
Totally agree, I was just saying........what if....... Craig Rogers
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Craig, are you going to be in water that deep? QRZ M8VPF
Hope not!
![]() But if last month is anything to go by............. It's all about the looks init bruv!.... ![]() 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Looks well
![]() Even though I have a snorkel (as it's dusty around these parts) ![]() |
I was thinking about sealing the doors shut as I don't want wet feet...... Craig Rogers
Cut your feet off... You'd save a fortune on socks and shoes
Didn't think about that.......hmm.
FOR SALE: Defender Puma pedal assembly. No longer required. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
