![]() | Home > Puma (Tdci) > 2.2 poor fuel economy |
Sorry m8s,
but the EU5 engines eats a little more fuel vs the same EU4 (remember TD5 EU2 vs.EU3?)....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
de-cat and remap
![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2671 ![]() ![]() ![]() |
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
roberty Member Since: 22 Jul 2009 Location: Malagas Posts: 2 ![]() ![]() ![]() |
I have a brand-new MY12 2.2 110 SW in which I recently undertook a 2,000 km trip across South Africa. I dilligently recorded full tank-to-full tank distances and corresponding consumptions for the trip which involved mostly open road cruising but also a week each of Durban and Cape Town city traffic.
Specific fuel consumption worked out at 26.22 mpg / 10.79 lit/100 km. I expected a figure in this ball-park from a new, tight engine and transmission and cruising at 120 km/hr, and it does not strike me as significantly different from my previous MY08 2.4 110 SW. In any event it should improve as the vehicle loosens up. As mentioned elsewhere in this thread, Defenders exported to South Africa are not equipped with DPFs. I can't say that I notice a difference in the the performance or driveability of the 2.2 vs the 2.4. However I must admit to the noticeably quieter cabin of the later Defender compared to the 2.4, and the total absence (believe it or not!) of rattles, squeaks and dust- and water-leaks. Remarkably the Defender beats my recently-sold MY11 Toyota Prado VX in the dust-proof department. Long may it last! |
AP90 Member Since: 04 May 2012 Location: London Posts: 13 ![]() ![]() ![]() |
Hi
I have a 90 2010 2.4 and I can only get 300 miles to a tank and I drive softly doesn't matter if urban, A road or motorway (70mph) 290 to 300 tops engine always seems unwilling and harsh...... Any ideas......... Thanks Ash |
Odin Member Since: 29 Apr 2011 Location: Aberdeenshire Posts: 237 ![]() ![]() ![]() |
Honestly? What have you done, spent £15,000 on it or did you steal the 2.4 in the first instance? |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 ![]() ![]() ![]() |
this was all said when the 2.4 first came out. with the 2.2 once the dpf is taken off, it won't be any different to the 2.4. like this topic is showing, every landy is different, even with the same engine. |
rover Member Since: 26 May 2012 Location: Yorkshire Posts: 150 ![]() ![]() |
I have a 2.2 110 sw, done 2500 miles so far, mix of motorway, a road and country roads, worked out the mpg every fill up and the average is 26.5mpg. Slightly worse then my previous Td5 at 28mpg but I suppose it may get better after a few thousand miles. I would not have the Td5 back though, 2.2 more powerfull, faster, less noisey, far better seating for pasengers, better at cruising at 70 mph better at towing the caravan.
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
My 2.4 90 would do 300/325 every single tank day in day out, I did get to see 400 a couple of times but this was escorting wide loads at 50mph for hours on end. The new 2.2 is only 250 miles a tank but it has to be said when the light comes on you only put 50 ltrs in where as the 2.4 light on 55 ltrs went in. If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
DavidITGuru Member Since: 16 Aug 2011 Location: London Posts: 99 ![]() ![]() ![]() |
I've been quie surprised by the poor fuel economy on my 2.2 110. I don't do big mileage so it's not the end of the world but my best / worst / average is only 23 / 18 / 21 which seems a lot thirstier than most. Admittedly the last few tanks (including the 1
![]() Am running 255/85/16 KM2s with spacers which probably doesn't help but I wouldn't have thought it makes that much difference. |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Speed will make the big difference. I am running 285s, full cage and about another extra 300kg in protection and recovery gear and still pull back 26-28mpg from my 2.4. But then again. Before the Defender I had a V8 Discovery returning a constant 20mpg, and before that a Rover Coupe turbo with 320bhp which returned 8mpg when driven hard- Why did I move on- was it because of economy?..... Well, when I drove the Coupe I dreamt of Land Rovers.... so got the Discovery at the right price..... but once I had that I dreamt of Defenders...... and well, now I have it I am over the moon...... it isn't about MPGs it is about that smile you have on your face and the good feeling inside when you see/ drive it. otherwise I would be like all the other douche bags who drive around in mind numbing uncharacteristic Jap/ euro boxes- what a boring way to live your life!! Glyn ![]() ![]() |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
2010 90 XS. I don't spare the horses and do a combination of country A/B roads , Motorways and minimal city driving with annual touring holidays on the continent. I have completed 26,777 miles
Over 9127 m ( 14689.9 K ) I have used 361.48 gulls ( 1643.32 L ) giving an average of 25.25 mpg ( 11.19L/100K ). Seeing as my previous vehicle was a Mazda RX8 which rarely got above 20mpg and used £700+ worth of tyres / year and 1L of expensive oil / 2000 miles ( it's designed to do that ) I have become more environmentally friendly. But who cares - I now enjoy every mile I drive. ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Well said. The "smiles per gallon" are huge in the Defender. I'd probably still have one if it returned 10mpg! |
