Home > Wheels & Tyres > Mantec Spare wheel carrier
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Hi all,
Ordered Mantec Spare wheel carrier which arrived last week. Looks pretty easy to fit - anyone else fitted one and if so any 'gotcha's to be aware of?
I'm still not looking forward to drilling out the rivets for the upper mounting bracket though... Rolling Eyes Cheers,
Superspoons
Post #161342 11th Aug 2012 9:56pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Pretty easy really, fitted one to my truck last January, see the last couple of photos in this thread:
http://www.defender2.net/forum/topic11080.html
Post #161367 11th Aug 2012 11:34pm
BigWheels
Been thinking of one, but they are expensive for what they are. Cheaper ones around sold by Paddock, for example. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #161546 13th Aug 2012 12:31am
dgardel
Italy
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #161624 13th Aug 2012 2:28pm
jont
2006 Defender 90 Td5 XS CSW Santorini Black
Had one fitted by pete and lewis from flatdog at billing yesterday and watched them do it ...
key points are remove door card carefully to avoid breaking the retaining clips ... gentle drilling out of the two left hand rivets in two stages ... check fit of mounting plate by offering up the bolts and plate from the outside first ... don't tighten the bolts on the lower hanger plate as you might need to ease the arm in to fit ... metal washers on the top of the top mount and the bottom of the bottom mount ... and piston mounting plate is offset so shorter side goes to the left/handle side of teh door
other than that it's probably a 45 min job
rgds
Jon
Post #161633 13th Aug 2012 3:26pm
superspoons
Thanks all for your replies.
Will do it this week and may post up a 'How to..." with pics if people think it's worth it?? Cheers,
Superspoons
Post #161672 13th Aug 2012 6:27pm
leeds
Like lots of things there are always cheaper options but are they as good?
A few things to consider. Are grease nipples fitted as standard? What size are the brackets? Reinforcing brackets? Where do the brackets mount? i.e. will they interfere with rear bumperette/NAS step fitment?
Brendan
Post #161691 13th Aug 2012 7:38pm
superspoons
Fitted
Fitted mine today. No real issues although Mantec's instructions need updating... minor points really. Only 1 rivet to drill out on the upper mount on mine and one new hole to drill. Plus the fitting plate on the door has bolts already on it. Took me about 2hours in total as I wanted to get it right.
 Cheers,
Superspoons
Post #162974 18th Aug 2012 9:58pm
superspoons
Was there a reason for the metal washer being on top of the top mount as the instructions show it as underneath?
My install below.
Top mount -
Bottom mount -
 Cheers,
Superspoons
Post #163287 20th Aug 2012 5:09pm
dgardel
Italy
superspoons wrote:
Top mount -
Bottom mount -
I installed my mantec in that way! Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #163288 20th Aug 2012 5:46pm
superspoons
Thanks. Thumbs Up
Just to confirm that the white poly inserts are located the same way too (mine were loose in the packaging after falling out during transportation).
I need to adjust it a little, as despite spending ages lining it all up I have a noticeable banging noise from the back. Can't see anything loose but will look closer when I have time. Cheers,
Superspoons
Post #163337 20th Aug 2012 8:32pm
ickle
mine knocked as well, I made up some round plastic shims to take up the play and its been silenced for over a year now...
Keith
Post #163362 20th Aug 2012 9:19pm
superspoons
Keith,
Thanks, but where did you fit the shims? On the main mounting bolts or the piston? Cheers,
Superspoons
Post #163376 20th Aug 2012 10:49pm
110SEB
Re: Fitted
Superspoons, shims are the least of your worries - someone's tipped your Defender onto its side Rolling Eyes Bloody vandals.
Post #163383 20th Aug 2012 11:21pm
superspoons
Re: Fitted
OK...you've got me... what are you talking about Question Cheers,
Superspoons
Post #163387 21st Aug 2012 5:41am
