![]() | Home > Wheels & Tyres > Mantec Spare wheel carrier |
I think SEB's monitor has fallen over
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1862 ![]() ![]() ![]() |
SS - I fitted them above the steel washer, in the pivot of the brackets.
Also make sure that the piston mount is tight. The plastic washer can make the rear door stiff to open, but it does stay open. I'll be at Eastnor if you're going and want a looksie. Keith |
Hi SS,
Yes that's correct. I used some flat plastic sheet, I think it was the side of a 25l used oil container IIRC and a hole saw, not knocked since. Good luck! Keith |
is that a genuine LR rear step? It would be good to kno mantec carrier is compatible. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Supacat....
Quick search reveals: Swing away carrier this post....Step next post.... ![]()
http://www.defender2.net/forum/topic11916....=rear+step If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 17th Oct 2012 8:27pm. Edited 1 time in total |
Hi I think it's a genuine nas rear step Ray Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
***Edit....**** Dgardel's rear step..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Seems to be a different part number for genuine or non-genuine and then part numbers are different again for 90 or 110...
Supacat,
Sorry just noticed yours is a 110. Obviously the genuine will be more expensive (by £100) but if it has the same mounting arrangements one would assume it would be compatable with the Mantec wheel carrier. Knowing Dgardel as we do nothing less than genuine would have sufficed. Maybe give him a 'pm' and phone the company perhaps to ensure you get what you require? http://www.lrseries.com/shop/product/listi...earch=rear step&page=1 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
