![]() | Home > Puma (Tdci) > Service bulletin Q068v2 |
That more like it Bob
expedition Member Since: 11 Sep 2009 Location: Vercelli-ITALY Posts: 75 ![]() ![]() ![]() |
...Hope for good!...
![]() 110 Td4 MY07 "E" Keswick Green |
Grockle, Don't be put off by all the negative feedback, mines running fine if not better
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 ![]() ![]() ![]() |
Just collected mine today. Q062 v2 software patch has resulted in much smoother running and cruising at 80/100km/h. "Pinking"/knocking at 1500-2000RPM in lower gears much improved but not totally eliminated. Also had transfer box replaced under warranty to try and finally cure drivetrain knock/judder when coming to a halt after a longish run. Appears to be OK after 50km run but due to travel 400km in a couple of weeks so hopefully will have a result by then.
I won't Karl,dealer says it's made all done so far better, but it was pulled in Aus earlier. ![]() 1968 1/32 scale Britains 109 Pick up. |
Mines better than before ![]() |
scatt Member Since: 24 Aug 2009 Location: nottingham Posts: 103 ![]() ![]() ![]() |
Ive been called by my landrover dealer today and they told me the software update is all well and good. They then asked if i'd like to drop it off for an hour and they will do it. obviously i took them up on the offer
![]() Its better in the midrange, im not sure if its and quieter but seems smother under acceleration. I think its time to talk to pete @ bell auto's for a proper re-map ![]() |
ok it's a diesel engine, it is impossible to eliminate the knocking...... but it's possible to reduce it with the right injection sequence and/or strategy..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
done today, smoother idle, less noise in mid range and [erception of being more smooth and more power
lrdxb110 Member Since: 09 Jul 2009 Location: Dubai Posts: 224 ![]() ![]() ![]() |
Mine went to the LR dealers here in Dubai today, I emailed the service bulletin to the service manager and they didn't even know about this service bulletin and first he told me this applies to defenders in the UK market only but after insisting to check he contacted their technical department and found out it applies for all cars between '07 to '09.
![]() '08 Mini Cooper S - Sidewalk '86 MB 500 SL '79 MB 450SEL 6.9 |
Ours is now like a formula 1 car,0-60 7secs top speed 120, jeez,Lewis Hamilton wants to borrow it ! 2.4 90 XS
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
Got mine back today and i have to say it seems smoother and less noisy - i can now hear more transmission noise (good or bad)
We will see how it runs. Mike |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Another thing I noticed was far less soot in the tailpipe.
I wiped my exhaust outlet with a rag and she stays clean for ages. Puma 110 - gone Series III 1973 - going strong |
rick Member Since: 07 Mar 2008 Location: Perth Posts: 133 ![]() ![]() ![]() |
Software upgrade done three days ago as part of an overall 20k service - much smoother at low-mid revs. It's suddenly a better vehicle to drive.
Cheers, Rick 1998 RR HSE 2007 RRS TDV6 2008 Defender 110 2015 Discovery Sport |
