Home > Technical > Help...
haworthj
Help...
.... I just got back from holiday. Good news, the Defender is still on the drive. Bad news, the battery appeared flat and on trying to start I just got a clicking. So I charged the battery overnight. It now starts as it should, but the red battery light is on constantly, the temp gauge shoots into the red instantly, even when the engine is cold, and It wont do more than about 25mph. Is this limp home mode? How do I clear this?
Any help really appreciated!
James
Post #161244 11th Aug 2012 10:07am
T1G UP
disconnect the battery again
leave it. re connect after 10 mins.
try again with a good battery.
if doing the same call landrover assist
Post #161251 11th Aug 2012 11:09am
haworthj
Thanks Marcus. Seems to have done the trick.
James
Post #161280 11th Aug 2012 3:09pm
haworthj
oh no, just tried again. still the same problem....with the key in the ignition, i can start the engine, but the rev counter doesnt work, the battery light is on...... argh!
Post #161290 11th Aug 2012 4:24pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Alternator on its way out? Euro-Leafing to infinity and beyond.....
Post #161402 12th Aug 2012 9:50am
Lorryman100
This is a known issue with the Puma and it is an ECU fault. If you can read the DTC's stored check for P068-A being logged as a tested DTC within the EMS. P068-A appears quite often if the OBDII socket is used to power a diagnostic tool or scangauge/ultragauge etc. However in conjunction with the Temp gauge in the red and the engine in limp mode this points to the ECU failing. If you are in warranty call out LR assist as long as the Puma is still showing this fault.
I have had the same symptoms a couple of times but it is easily checked for a fault in the harness by following the tech bulletin. My issue was the OBDII socket and after I rectified the issue the fault has yet to reappear. Point to note not mentioned in the above bulletin is that if the fault happens with the engine running it goes straight into limp mode but no MIL will show and you will struggle to get above 25mph.
Post #161416 12th Aug 2012 11:04am
callummb2
United Kingdom 2009 Defender 90 Puma 2.4 HT Java Black
HI could some one send me the teck bulletin on how to check the wiring as mention in Lorryman100 last post.thanks
Post #931400 27th Nov 2021 11:50am
The tech bulletin is actually contained in Lorrman100's last post. Darren
Post #931577 28th Nov 2021 5:14pm
