| Buzz Member Since: 11 Oct 2011 Location: Inverness Posts: 235
Turned the Defender into a summer holiday play park!
Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
@buzz - where's the liquid sunshine ?
Being in Inverness-shire, we seem to have done quite well just lately! |
Click image to enlarge Out on the West Coast... Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6018
Tonight had a go at re-sealing my leaking Alpine window seal. I purchased some Sikaflex 291i.
Cleaned up around the seal and degreased and while cleaning up the area and re-adjusting the seal had split behind the filler strip. So fingers crossed its sealed. just need a good down pour to test the seal now (hopefully the Sikaflex will set before then) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314
.... Pulled the trunk of a Eucalyptus tree (8ft tall and 10inches wide) from the ground of the front garden via a strap. Great fun. Cheers,
Superspoons |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939
Sounds interesting ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632
Well, I finally got around to fitting my Entreq nud flap brackets, as detailed down the page in this thread:
http://www.defender2.net/forum/topic10722-15.html Pete |
| Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026
Spent 5 hours on Defender4's black 90 under the bonnet, interior, sealing the capping's and wire brushing/acid treating the minor rust underneath. Just need to cavity wax the chassis and Dinitrol the rest outside, another 4-5 hours so will start early to beat tomorrows heat!
Word of warning - Dinitrol usually give you a boiler suit, hat, mask etc in the kit but this wasn't present so it will be a trip to Halfrauds first thing to get covered up This is an 07 model in VERY good condition as it is garaged BUT it still has corrosion which is a PITA - If anyone buys a new one GET IT DONE ASAP, straight from the dealership if you can, it makes a huge difference in condition and preventing all the corrosion problems so many seem to be returning to dealerships for - spend £150 and get a couple of cans of AFC-50 and a kit from Dinitrol, It's the cheapest and best way to spend money on your Defender |
| IanW Member Since: 12 Jun 2011 Location: Gloucestershire Posts: 172
Stuck Defender2.net stickers on the truck and thought afterwards I should have found the spirit level. One wife - livid
^^^^ I had the same issue infact so much so I took it off and had to buy a new one.
Forgot to mention this was my second. Blame the sloping drive. One wife - livid
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785
Come on then Ian, let's see it! Get a photo of your handy work uploaded Russell
2011MY 110 XS USW Black |
| glyn.c Member Since: 30 Oct 2011 Location: east devon Posts: 33
GLYN |
