![]() | Home > Puma (Tdci) > Two stroke oil and DPF |
| martin010161 Member Since: 14 Mar 2012 Location: Dereham, Norfolk Posts: 17
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
I remember reading up on the use of 2 stroke in diesel a lot before I started using it and I am sure that with a dpf it should not be used.
An expert wil be along shortly to correct me I am sure Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
| Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159
I tried 2so and my mpg dropped by 10%
2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
| kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987
will be using 2so when the new 90 comes , 500ml per tank so I will let you know, over 300,000 miles on the 2.4 with 2so so not going to change a habit now
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
Only if you use the wrong spec. For vehicles with DPF, JASO-FC only! -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Ok thanks for info guy's, still need more thought
Hi,
Today I have purchased a quantity of Castrol Act>evo two stroke oil, stated on bottles as Jaso-FC, cost £5.96 per litre. The decision to start using 2so has now been made No immediate difference noted but will see how things progress. |
| Staftly Member Since: 06 Jul 2012 Location: Lancashire Posts: 55
Hi Martin010161, any update to give? I am considering 2so for my new 2.2 utility. Also, what quantity do you use, I guess you have researched this.
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680
Have been using Castrol FC graded 2SO in the BM with PDF for about 18 months and 18000 Miles no issues so far I use 250ml per fill up and use BP Ultimate (if I can), DEFENDER 90 TDCI XS,
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
If you use BP Ultimate, why still use 2SO on top of that? I switched to BP Ultimate too, and since then my engine is as smooth as can be. Much less diesel knocking and when turning off, the EGR cleaning cycle is much quieter too.. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
Ill be a bit out of line here, maybe.
This is a general 'forum wide' comment and it has no agenda with any particular individual. There is a lot of talk about using Land Rover specific oils, using the exact grades etc for gearbox/engine/transfer box, why use 2 stroke oil, when it's not specified as a type of fuel to put in? Click image to enlarge QRZ M8VPF |
| All times are GMT |
