Home > Puma (Tdci) > Two stroke oil and DPF
martin010161
Question Will using two stroke in a 2.2 Puma be ok? could it affect the DPF?
Post #131363 14th Mar 2012 7:13pm
bob neville
I remember reading up on the use of 2 stroke in diesel a lot before I started using it and I am sure that with a dpf it should not be used.
An expert wil be along shortly to correct me I am sure Thumbs Up
2013 Defender 90 CSW - sold
Post #131366 14th Mar 2012 7:25pm
rossy
well I'm no expert but there's enough threads on 2SO in the archives of Def2 for a thesis.
As I understand DPF equipped motors can use 2SO provided it is Jaso FC spec which produces less ash than FB. The catalytic converter can cope with a bit of ash but the DPF doesn't like it as it won't burn off
Hit the search button and you'll find many a discussion on the pros and cons Thumbs Up
Post #131431 14th Mar 2012 9:46pm
Toplink
I tried 2so and my mpg dropped by 10% Big Cry So I don't use it anymore,first tank full without 2so and mpg returned to normal.Perhaps the exception that proves the rule. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2014 Triumph Tiger800xc
1999 Discovery 2 td5
1982 Ransomes TSR300D.
2002 Yamaha XT600e.
2010 Freelander2 (the wifes)
2008 John Deere X140
Post #131436 14th Mar 2012 9:50pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
will be using 2so when the new 90 comes , 500ml per tank so I will let you know, over 300,000 miles on the 2.4 with 2so so not going to change a habit now Very Happy
Post #131453 14th Mar 2012 10:35pm
Naks
Re: Two stroke oil and DPF
Only if you use the wrong spec.
For vehicles with DPF, JASO-FC only! --
Post #131542 15th Mar 2012 11:51am
martin010161
Ok thanks for info guy's, still need more thought Question
Post #131547 15th Mar 2012 1:33pm
martin010161
2 stroke oil
Hi,
Today I have purchased a quantity of Castrol Act>evo two stroke oil, stated on bottles as Jaso-FC, cost £5.96 per litre. The decision to start using 2so has now been made Surprised
No immediate difference noted but will see how things progress.
Post #133345 22nd Mar 2012 9:55am
Staftly
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Hi Martin010161, any update to give? I am considering 2so for my new 2.2 utility. Also, what quantity do you use, I guess you have researched this.
Post #160001 4th Aug 2012 11:31pm
LR90XS2011
Have been using Castrol FC graded 2SO in the BM with PDF for about 18 months and 18000 Miles no issues so far I use 250ml per fill up and use BP Ultimate (if I can), DEFENDER 90 TDCI XS,
Post #160014 5th Aug 2012 7:24am
ericvv
If you use BP Ultimate, why still use 2SO on top of that? I switched to BP Ultimate too, and since then my engine is as smooth as can be. Much less diesel knocking and when turning off, the EGR cleaning cycle is much quieter too.. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #160016 5th Aug 2012 7:31am
Ill be a bit out of line here, maybe.
This is a general 'forum wide' comment and it has no agenda with any particular individual.
There is a lot of talk about using Land Rover specific oils, using the exact grades etc for gearbox/engine/transfer box, why use 2 stroke oil, when it's not specified as a type of fuel to put in?
 QRZ M8VPF
Post #160019 5th Aug 2012 7:47am
