![]() | Home > Maintenance & Modifications > 90 brakes upgrade |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Yep .. EBC slotted/drilled discs and EBC pads.
Fitted front and rears on mine ... 'standard' braking feels no different ................ but brake harder and WOW ! Guns and Landrovers .... anything else is irrelevant. |
chipmunk Member Since: 10 May 2012 Location: Kelso Posts: 264 ![]() ![]() |
Thanks Dave will suss prices.
Dave |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
Ive used EBC on other cars and bikes with good results, go direct to thier web site for the best deals and they are UK made DEFENDER 90 TDCI XS,
Having Delphi/Lockheed discs and TRW pads fitted to the 90 next week.
Be difficult to do a comparison to whats on now as the discs are almost non existent ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17913 ![]() ![]() ![]() |
You found some then. ![]() |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
How does that affect the traction control? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Shouldnt make any difference ... I know Landytom has this set up on his 110 with ABS/TC and he has had no issues... ? Guns and Landrovers .... anything else is irrelevant. |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
It won't affect the electronic systems. EBC and similar pads just give slightly more initial bite and don't fade as much as a standard compound pad. The Green Stuff pads are OK, but do demand some heat in them to get them to work effectively. I ran them on a Range Rover for a few years, and being an auto, you had to reign it in on the first few brake applications and then the pads appear to be OK after that. As you probably know, EBC do a few blends of pads for specific applications.
On the Range Rovers, EBC sold a 'SUV' pad starting with the part number 6xxx, and also a heavier duty pad starting with a 7xxx. The 7 series pad was far superior to the 6, but I have not researched the Defenders. The compound was the same but the metal backing on the 7 series was much thicker, which helped when the caliper pistons pushed out on them, and perhaps the metal helped with moving the heat away from the pad surface? Slotted discs are OK, and help keep the face of the pads nice and flat. Drilled are not really worth it, and on lesser brands can actually contribute to cracking as heat can build up at the point where the hole is drilled. The better ones are chamfered to prevent this. SuperPro Europe were importing and distributing some Aussie versions of the EBC's, but I have not seen anything recently promoting them. |
Im running standard compound EBC on the BM and the brakes are stonking much better than the OEM and have lasted longer so far than the originals, no evidence of scoring etc on the disks at 40k miles so very hp. Cost £60 for all four wheels about 18 months ago which was about 1/3 the cost of OEM from BM. DEFENDER 90 TDCI XS,
boode Member Since: 11 Apr 2012 Location: Devon Posts: 436 ![]() ![]() ![]() |
Has anyone used the Disc Brakes Australia 4x4 survival Discs ?
Good reviews but not sure if available in the UK ? |
mr_tdi82 Member Since: 24 May 2011 Location: Henley on Thames Posts: 62 ![]() ![]() ![]() |
have ebc green stuff pads 7 series and discs slotted not drilled, all round. very good so far. got mine from cam skill very good prices.
Those were the ones who SuperPro Europe were distributing. |
