Home > Technical > Power loss in hot weather?
Page 7 of 7 <1234567
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
dgardel wrote:
wslr wrote:
But if there is something in the original software causing this... Confused
Yes, it is related to certain SW version, expecially on the cars upgraded P089 (for solve the cool weatber starting issue). I'm shure at 99%
I wonder about this?.......
Why then does the remap not change it completly?
Or is there a safety feature that is not over-writen by a remap?
Post #158252 27th Jul 2012 9:25am
wslr
I think the only people who can answer this would be the tuners?
I know the map files are quite large on the Puma (well, larger than the Td5), so I'd guess that most of this data would contain the programming to cause this fault under a certain condition. I'd presume that this would be able to be adjusted by a tuner, but at what risk to the vehicle?
Post #158254 27th Jul 2012 9:31am
dgardel
Italy
Normally the remap write only a part of the sw like 3D fuelling, turbo, advance, ...... surfaces, not the whole sw like firmware for the processors, algorithms, .......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #158268 27th Jul 2012 10:29am
T1G UP
i don't think they even go that deep TBH.
Post #158269 27th Jul 2012 10:33am
ZeDefender
wslr wrote:
ZeDefender wrote:
My LR techie told me recently that my software version is bang up to date.
Was the source of this software JLR (via IDS/SDD) or from another source (e.g. Autologic)?
I'll ask when I go there next - always worried I'll sound stupid though Whistle Tell someone you love them today because life is short.
Post #158278 27th Jul 2012 11:31am
Morea
Post #158279 27th Jul 2012 11:31am
Morea
This is what happens to me. Sorry about the comments are in Spanish and is very difficult to conduct and record at a time. It looks at minute 5.53. It is very mild, just as it passes the slope and the terrain is flat. If the slope is longer def takes much more in reacionar vaja speed and max 40 or 50km / h, till they recovered. On Thursday it enchufare to a friend's computer and try.
&feature=youtu.be http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #158947 31st Jul 2012 3:47pm
dgardel
Italy
Morea,
in my opinion the temperature gradient is too much fast.....
I'm thinking about a sort of electrical signal "derivation" or something else.
Should be interesting to monitoring the fact by a nanocom for recording the engine temp and other sensor outputs...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #158958 31st Jul 2012 5:16pm
dgardel
Italy
by the way, 34 °C here in Venice area and the car still going fast.
BAS remap, Allisport uprated intercooler, hybrid turbo.
Should be interesting to monitor the fuel temp also. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #158960 31st Jul 2012 5:18pm
Morea
dgardel wrote:
Morea,
On Thursday it will plug in and watch the engine to run everything. Thank you very much for your help.
Good preparation. That fuel consumption is now? Thank you. http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #158977 31st Jul 2012 7:35pm
