Home > Technical > Does rust stop?
ZeDefender
Does rust stop?
Okay, ignoring A-Level chemistry and all that theoretical bunkum about rust needing oxygen and water:
If I clean off all the loose rust from a door sill (and don't treat it) and cover it in something like Sikaflex to prevent water or oxygen from getting to it, will it continue rusting underneath?
That's probably an unbelievably stupid question but Google was unbelievably useless... Tell someone you love them today because life is short.
Post #157570 23rd Jul 2012 10:33pm
K9F
Re: Does rust stop?
ZeDefender wrote:
Okay, ignoring A-Level chemistry and all that theoretical bunkum about rust needing oxygen and water:...
Don't ignore it! The answer lies in your question. Thumbs Up
No! But make sure it's bone dry with no air bubbles.
Also why not treat it before you Sikaflex it?...Fertan is a great rust killer.
http://www.classic-oils.net/Product-340/Ga...-Convertor If you go through life with your head in the sand....all people will see is an ar5e!!
Post #157573 23rd Jul 2012 10:55pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Surely moisture must be the problem as plant and machinery including defenders used in underground salt mines does,nt rust due to the very dry atmosphere down there,So in theory if you can keep it dry the rust would lie dormant,Would,nt it? 2005 Td5 90 XS
Steve
Post #157575 23rd Jul 2012 11:04pm
ZeDefender
Thanks guys - it was just a bit hard to believe with all the rust-horror stories you hear.
I will fit my last stainless sill (in the dry, after Kurust treatment) with some Sikaflex and peace of mind Thumbs Up Tell someone you love them today because life is short.
Post #157578 23rd Jul 2012 11:09pm
JWL
Ah c'mon, Defenders are like sugar.........they're hygroscopic!
Post #157579 23rd Jul 2012 11:10pm
ZeDefender
Laughing
Don't you mean "carbohygrates"? Wink Tell someone you love them today because life is short.
Post #157582 23rd Jul 2012 11:14pm
Kurust should sort it for you providing you remove all traces of the rust already present. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #157646 24th Jul 2012 10:37am
T1G UP
there are a few tidy td5s and santanas over here that haven't got must rust. moistures the killer
Post #157651 24th Jul 2012 10:41am
As stated by others above, the rust will stop provided you remove all the necessary conditions from the substrate. In practical terms since rust is porous, it is essential that you remove all existing rust before painting. In the case of light surface rust, cleaning it off with abrasives is fine, but in the case of heavier rust you would be foolish not to use chemical treatment since it is in effectively impossible to remove all the old rust by other means (the exsting rust will trap the moisture/oxygen needed for rust to continue).
All chemical treatments are in effect acid based, and IIRC convert the existing third oxide of iron, namely rust (ferric oxide, Fe2O3) to the much more stable second oxide of iron, ferrous oxide (FeO) which provdes an extremely stable surface. Fertan is one such treatment (using, I think, Tannic acid, presumably hence the name), but other options are available.
On major steam restorations I have carried out I have used a dilute organo-phosphoric acid supplied expressly for surface preparation prior to painting, which has two benefits. Firstly it converts any remaining rust to forrous oxide, and secondly it provides a lightly etched surface ideal for taking the primer. The acid should be brushed on lightly, just enough to dampen the surface (no runs) and when dry, 'scotchbrighted' to grey. Primer and subsequent colour coats should then be applied in the normal way. This results in an extremely durable finish which meets industry adhesion standards. I appreciate that this may be of little relevance since most Defender owners won't want to buy a 5-gallon carboy of acid, but the off-the-shelf products (like Fertan) shoudl give as good results albeit at a much higher cost per square metre.
Post #157678 24th Jul 2012 1:05pm
ZeDefender
Wow - you're like "the Lorryman100 of rust" Thumbs Up
Obviously, there is a right way (your way) to do these things (and I will) but just out of interest, when you say "the existing rust will trap the moisture/oxygen needed for rust to continue", how much will it continue if there is only a little bit of moisture/air trapped and the surface is sealed in (e.g. with Sikaflex)? Won't the rust stop pretty quickly?
This was really my original question... but I'm not always clear Rolling Eyes Tell someone you love them today because life is short.
Post #157687 24th Jul 2012 1:46pm
K9F
Ze,
Having gone to the trouble of stripping/prepping the area, why would you NOT treat it? Unless your uncontrollable urge to fit and the lack of a suitable rust treatment to hand is fighting against the sensible thing to do. In which case I fully understand and sympathise wholeheartedly!
Laughing
Wait and treat would be best! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #157691 24th Jul 2012 1:53pm
The answer to the first question ("how much will it continue") is that it will continue until there's nothing left to rust, if untreated. As soon as the rust starts up again the paint will come off, the rust will accelerate, more paint will come off, etc. Any residual rust will inevitably lead to more rust, and rust will spread quite happily underneath the paint surface.
As to "won't the rust stop pretty quickly" the answer is no, unless you remove it completely or convert it into something other than rust.
Sadly, as a great many people have found over the years, there is no easy cure to rust and half measures don't work. Plenty of things will slow down the spread of rust, but only hard work and elbow grease will stop it.
Those of us who remember cars (especially British cars) of the 60's and 70's will appreciate that modern factory treatment is fantastic now compared to then, and we are actually quite lucky. My first car (a 1966 Triumph 2000 Mk1 estate) used to need new sills or other rust repairs every year for the MOT, until it simply got to the point that there was nothing left to weld new material to. I scrapped it when it was 20 years old. If you look at cars from 1992 you will find that now there are plenty which are completely rust-free still. Not Land-Rovers, admittedly, but you have only to look at a Defender to see that the 1960's are alaive and well! It is, after all, why we love them!
Post #157707 24th Jul 2012 3:18pm
ZeDefender
Thank you all Thumbs Up All the info has been extremely helpful.
Believe it or not, one of the main reasons I bought the Audi A2 is because it is aluminium and the frame won't rust. All my previous cars rusted to pieces and I thought Rolling Eyes the Defender wouldn't rust either Rolling with laughter Shocked Big Cry Laughing
Thanks to Zagato I've started spraying everything with ACF and gradually all the leaky seals are being replaced and the corrosion treated/prevented.
But I'm slightly paranoid (TBH one of the reasons for the post) because I've got one last Entreq stainless sill to fit and I've noticed a bit of rust where I'll fit it. I'll deal with it but I don't think I checked the others carefully enough Sad
Trying to decide whether I should take them all off again... Tell someone you love them today because life is short.
Post #157721 24th Jul 2012 4:00pm
T1G UP
be careful fitting s/s product with steel, ali
read this...very interesting Lasagne part!
http://www.bodyshopbusiness.com/Article/31...ation.aspx
Post #157735 24th Jul 2012 5:22pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Post #157745 24th Jul 2012 6:23pm
