Home > Maintenance & Modifications > Puma: burnt headlamp relay
Molusk
France 2008 Defender 130 Puma 2.4 HCPU Alpine White
Hello,
last october I had problems with my puma's headlamps. As it was still under warranty, I drove it at the nearest dealer, who solved the problem by replacing the relay.
Back home, I noticed that the relay holder has burnt. Not melted, but hot enough to change the color from yellow to brown. I guessed the previous relay was the cause of this.
But last night I had to face again same headlamp issues: only side lamps light when I switched the headlamps, then headlamps OK after 2-3 switches. So I checked the relay, and after few miles it was clearly hot. I stopped and I swapped the faulty relay with the next one (for heated rear window, and as I have 130DC, it is useless). It worked fine, and during the way back home, I checked it several times, it was just warm, not hot.
So I start to think the route cause is not the relay itself. Do you think the relay holder may be faulty? something else?
Thanks for help,
julien.
Post #157410 23rd Jul 2012 9:24am
K9F
Root cause.... Thumbs Up
http://www.defender2.net/forum/topic13683....amp+switch
http://www.defender2.net/forum/topic13748....amp+switch
http://www.defender2.net/forum/topic13958....amp+switch If you go through life with your head in the sand....all people will see is an ar5e!!
Post #157427 23rd Jul 2012 12:08pm
Molusk
Post #157438 23rd Jul 2012 1:55pm
Molusk
Moreover, as there is a relay, I guess the current through the switch should be very low, shouldn't it?
Post #157441 23rd Jul 2012 2:14pm
K9F
Did you read the links I posted? Whistle
Taken from the third link....The current should be low but it obviously isn't...
ben_j85jty wrote:
Its the head lamp switch. The current for the lamps runs through it and it often fails.
As documented it IS a common fault. Dismantle the switch and have a look at the detailed contact, or just ignore it until the switch fails, probably at the most inconvenient time!... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #157455 23rd Jul 2012 2:46pm
Molusk
I did read your links, but how a faulty switch makes a relay burn? And why when replacing the relay everything is back in order?
Post #157461 23rd Jul 2012 3:18pm
K9F
Is this a wind up? I am just trying to help and have given you the information you need.....
Basic electrics from a basic (well maybe not so basic) electrician..... Whistle Laughing
If the resistance of the switch is reduced through burning/shorting out the current in the circuit will increase and exceed circuit limitations. This may take some time in the case of a relay drawing more current than it should before it eventually burns out.
Replacing a burnt out relay without finding the cause is just a 'sticking plaster' fix as that relay may possibly also burn out.
Voltage=Current X Resistance.
Therefore...
Current = Voltage divided by Resistance
And
Resistance = Voltage divided by Current.
Also Power (watts) = Voltage x Current.
Just check the friggin' switch it'll not take long and if there's nowt wrong forget it. If not we could theorise and surmise for ever what may or may not be wrong....Please! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #157481 23rd Jul 2012 4:56pm
ZeDefender
Wine time... Tell someone you love them today because life is short.
Post #157496 23rd Jul 2012 6:11pm
leeds
Yes the main switch does burn out as I well know.
However since the relay base is discolouring suggesting heat build up there, could it be bad contacts within the relay holder?
I would be tempted to check the light switch, to replace the relay holder and check, clean and tighten the terminals/contacts on the relay holder.
Poor contacts can causing sparking etc and increase heat.
Those comments are from a non sparky.
Brendan
Post #157506 23rd Jul 2012 6:40pm
Molusk
Firstly, thanks to all of you to try to help me to solve this burning relay issue.
I checked the main switch, and the dipswitch. Both of them seem in perfect working order (no burning, no melting).
I took some pictures of the relay, and the relay holder, to show you:
We clearly see there was an overheat in the holder area, but no short circuit as the blue wires are discoloured only close to the terminals. So the question is: terminals/holder faulty, or the relay itself?
According to the fact the relay has been changed less than 1 year ago for the same reason, I guess the root cause is elsewhere. Moreover, here are some pictures of the relay:
I see no burning, no melting, nothing.
So it seems that the trouble comes from the holder and its terminals, no?
It was my first idea, but I do not see any spark when lights are on. And assuming one terminal is not properly crimped, OK for an overheating zone around these terminal. But how comes I have overheat marks on 2 terminals? And the wires seem to be correctly crimped behind these terminals... Neutral
PS: no need to remind me the Gauss Law Mr. Green
Post #157561 23rd Jul 2012 10:04pm
K9F
I would remove the relay, remove/disconnect the headlights, remove the fuses and carry out an insulation check of all the associated cables between each other and to earth. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #157565 23rd Jul 2012 10:15pm
I have before now seen a similar effect when the female part of the spade terminal has been badly formed, is corroded, or is not tight on the male part, resulting in a high impedance at the connection.
It might be worthwhile extracting the female parts from the plastic holder (the retaining clip can normally be freed with a jewellers' screwdriver) and thoroughly cleaning them, and then checking that they are a snug fit on the male connector. When satisfied, refit into the holder shell.
Post #157686 24th Jul 2012 1:31pm
K9F
Excellent point Brendan/Blackwolf. I've witnessed this too with a green 'furred up' deposit! Thumbs Up I would carry out your suggestion prior to insulation testing. As long as you don't insulation test the coil of the relay you could leave the relay connected and test through the contacts. This would also prove/disprove the corrosion/bad fitting theory. Naturally that is if you have access to an insulation tester of course. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #157688 24th Jul 2012 1:47pm
Molusk
What I plan for tonite:
- measuring current through the relay
- measuring internal impedance of the relay, when closed of course, and comparing with new one's. I will perform this measurement on the relay terminal directly (with relay on the shelf, but feeded with flying wires from a 12V battery), then from the holder terminals with relay back in place.
- with IR T°C sensor, measuring T°Cgradient between relay and relay holder.
Post #157722 24th Jul 2012 4:12pm
Moffett
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I have this exact issue, switch appears okay, long time ago I know, but what did you find?
Post #937689 14th Jan 2022 1:14pm
