|  | Home > Puma (Tdci) > used approved warranty |
| DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312      | Scary there was that much wrong though!
 Does make you consider te extra warranty though. Darren | ||
|  16th Jul 2012 5:55pm |
| slick75 Member Since: 08 Dec 2011 Location: s wales Posts: 36      |
 Yes, had considered the extra warranty, but doesn't look like it covers much for the 400 odd quid it is.  08 def 90 ht stornaway grey | ||
|  16th Jul 2012 6:02pm |
| familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3502      | Trying to have a leak free defender from oil coming out or water going in.....
 Resistance is futile my friend  1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI | ||
|  17th Jul 2012 10:22am |
| Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677    | my defender also suffered from leaky seals.. few bolts missing when i bought it, windscreen wipers that decided not to work every now and again, also had a tiny bit of corrosion on the corner behind the dash so asked them about that, full new bulkhead window frame the lot, about 1" square of rust was all that was found.. just over 3 weeks without my defender currently in a courtesy defender of theirs with the loudest tires know. | ||
|  17th Jul 2012 1:02pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      |
 That's very cheap......I was offered one which worked out nearly £70 per month....   http://www.defender2.net/forum/topic7586.html?highlight=extended http://www.defender2.net/forum/topic5652.html?highlight=extended If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  17th Jul 2012 1:14pm |
| Landie Boy Member Since: 14 Jan 2011 Location: Essex Posts: 431      | Worked well with our disco 3, 2 new differentials, new ignition, new fuseboard, new front axle hub.. That's on the second year of the extended warranty. Well worth it
 Jack | ||
|  17th Jul 2012 4:28pm |
| Posting Rules
