Home > Puma (Tdci) > used approved warranty
slick75
Wales 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Hi guys,
Just had a lot of work done under the above warranty, after three years manufacturers ran out I had one years used approved from stratstone.
I booked it in for, leak from rear diff, leak from transfer box and leak from front swivel housing, they did all that and they found more problems which were, leak from rear break calliper, which they replaced and leak from break servo unit which they also replaced, and a few other little jobs which they found.
All in all, was in dealers for two weeks Big Cry
Glad I didn't have to pay for that bill. Thumbs Up Mr. Green Very Happy
Hope this helps for anyone else coming up to their end of warranty. 08 def 90 ht stornaway grey
Post #155955 16th Jul 2012 5:57pm
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Scary there was that much wrong though!
Does make you consider te extra warranty though. Darren
Post #155958 16th Jul 2012 6:55pm
slick75
Yes, had considered the extra warranty, but doesn't look like it covers much for the 400 odd quid it is.
Smile 08 def 90 ht stornaway grey
Post #155962 16th Jul 2012 7:02pm
familymad
Trying to have a leak free defender from oil coming out or water going in.....
Resistance is futile my friend Laughing 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #156095 17th Jul 2012 11:22am
Likeomg
my defender also suffered from leaky seals.. few bolts missing when i bought it, windscreen wipers that decided not to work every now and again, also had a tiny bit of corrosion on the corner behind the dash so asked them about that, full new bulkhead window frame the lot, about 1" square of rust was all that was found.. just over 3 weeks without my defender currently in a courtesy defender of theirs with the loudest tires know.
Post #156143 17th Jul 2012 2:02pm
K9F
slick75 wrote:
doesn't look like it covers much for the 400 odd quid it is. Smile
That's very cheap......I was offered one which worked out nearly £70 per month.... Whistle
http://www.defender2.net/forum/topic7586.html?highlight=extended
http://www.defender2.net/forum/topic5652.html?highlight=extended If you go through life with your head in the sand....all people will see is an ar5e!!
Post #156148 17th Jul 2012 2:14pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Worked well with our disco 3, 2 new differentials, new ignition, new fuseboard, new front axle hub.. That's on the second year of the extended warranty. Well worth it
Jack
Post #156206 17th Jul 2012 5:28pm
