Home > Maintenance & Modifications > calipers
womble
calipers
has anyone fitted bearmach front brake calipers to a 110?how long ago and did you have any problems with fitting them or in use?just been looking at prices and they are a lot cheaper but it's brakes and not worth it if they are nowhere near as good.advice please Thumbs Up
Post #155528 14th Jul 2012 2:11pm
wslr
Find out if the part is OEM. That will give you an idea of how good the quality is. IIRC, Bearmach tend to put an 'R' at the end of the part number if it is a replacement (i.e. not OEM) or a 'G' at the end if it is OEM quality.
Normally, the Bearmach stuff is pretty good.
Andrew at Defenderbits tends to carefully check quality from Allmakes and Bearmach, so it may be worth calling him. Credit to him, he only sells stuff that works.
Post #155578 14th Jul 2012 5:38pm
Be really carefull with brakes, a few years ago, an enthusiast fixed his brakes and ended up in a river with really dire consequences - use genuine parts they could save your life
Post #155593 14th Jul 2012 6:49pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Or strip, fit new seals and stainless steel pistons (about £100 ish for a complete set) and reassemble Thumbs Up
Boy
Post #155639 14th Jul 2012 8:57pm
Amongst other things, he had different calipers on each side I think.
Post #155658 14th Jul 2012 9:48pm
womble
thanks people.going to croatia in the 110 next month and probably towing a horsebox(without livestock i must add)just furniture and calipers are playing up a bit .think i will go down the top quality route.thanks again.i love this forum ......always sound advice Smile Smile Smile Smile Bow down
Post #155661 14th Jul 2012 10:04pm
JSG
Correct, plus some 'home brewed' suspension mods with suspect welding IIRC. John
2011 Tdci 110 CSW XS
Post #155850 16th Jul 2012 9:20am
Caterham
Censored ! I've got some bearmach ones ending in R. I'd like em to work when needed - should I fit em or not?
Post #517943 26th Mar 2016 4:07pm
Thon
Boy
LAst Thursday I ordered a set of SS replacements from Zeus Engineering for my 2007 110 and they were just over £60 for the set of 12, which I thought was very good value.
I'm going to use genuine seals though as I heard OEM or pattern can be a bit variable. They no longer seem to show these on the Zeus website, although they do show all of the braking conversions they produce for older leaf-sprung trucks. My calipers are original but with low mileage the pistons have been exposed to the elements too long and are unrecoverable.
Post #517944 26th Mar 2016 4:16pm
Fatboy Slim
Wales
They'll be absolutely fine. Sell them to me if you don't want them Whistle
Post #517975 26th Mar 2016 5:58pm
Caterham
Cool. Just need th weather to cheer up then figure out how to fit em?
Post #517992 26th Mar 2016 6:46pm
Fatboy Slim
Wales
Two bolts and one pipe. Dab of loctite on the mounting bolts when you fit the new ones. Pads in and bleed up. Personally I'd pop the pistons out and change them for stainless but each to their own.
Post #518009 26th Mar 2016 8:09pm
Caterham
Agreed. I fancy refurbing the old calipers with ss pistons and perhaps a coat of paint?
Post #518029 26th Mar 2016 9:07pm
