Home > Puma (Tdci) > Second technical problem with my MY2012 Defender
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Hi
Today just below 11.000 km ( car less than 3 months old) my defender faced its second technical failure.
1st was turbo hose
2nd water hose. The waterhose running from the pump to the block was cut by a intercoolerhoseclip. This was in the middle section of the hose. Seeing the installation, others will face the same problem. It is just à matter of time the clips will cut trough.
I have made some pictures but I cannot upload these until Friday.
The problem came up on acceleration. There was an acute powerloss. The temp went from normal to extreme in 2 seconds.
Regards
Q.
Post #155022 11th Jul 2012 6:05pm
Kevan
2012 Defender 110 Puma 2.2 SW Keswick Green
Puma 2012 similar issues
Dear Q
My landy is in now for the Turbo Hose at 9700km, should I get them to replace the water hose clips,
thanx
kevan
Post #159276 1st Aug 2012 10:11pm
RedDef
Australia 2012 Defender 90 Puma 2.2 SW Firenze Red
Hi,
I had the Turbo hose go at about 2000km, just found the same clip rubbed through a radiator hose at 13,000km.
recall timer on poorly placed hose clips?
All the best
RD
Post #161792 14th Aug 2012 9:43am
Tony
United Kingdom 2012 Defender 90 Puma 2.2 SW Keswick Green
Thanks Q for making us aware of this, sorry to hear you and RedDef had to find out the hard way. Checked my water hose last weekend and it was also starting to rub on the same hose clip (after just 1500 miles) so I've put a piece of rubber around the intercooler hose and used a cable tie to pull it gently back towards the inner wing and away from the water hose. If the hose clip was turned through 90 degrees when fitted there wouldn't be a problem!
Cheers! Thumbs Up
Tony
Post #162497 17th Aug 2012 12:45am
Forest of Dean 90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
My inter cooler hose went, turns out the pinch bolt on the steering column rubs the hose (great design)
Post #162507 17th Aug 2012 7:50am
BarneyRubble
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
The power loss and temperature issue may be to do with a loose connection on the main power relay.
I had lots of trouble with power loss and unexpected stalling, on the third attempt a Land Rover Assistance guy spotted the temperature gauge was at the max and said this was a common sympton of loose connections.
Having tightened all the crimps on the relay base, I haven't had the problem since. Barney
D4 - 2016 Graphite, Montalcino Red
Written Off - 2010 90 Hard Top, Stornoway Grey
Post #162512 17th Aug 2012 8:14am
That's a common fault. Thumbs Up QRZ M8VPF
Post #162532 17th Aug 2012 9:13am
