Home > Technical > Biodiesel?
mowcop
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
Biodiesel?
Just being lazy, can we use supermarket style Biodiesel in the Tdci?
Post #15423 13th Sep 2009 6:41pm
vogue se
Belgium 2011 Defender 90 Puma 2.4 Exclusive HT Nara Bronze
No, according to the manual, you can't use full biodiesel and also no diesel containing a % of biodiesel.
Post #15434 14th Sep 2009 7:04am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
By law you're OK up to 5%. Jury is out on whether it makes any difference after that. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #15439 14th Sep 2009 10:11am
discocuzzy
You will stink of skate wings and seveloys though! You cannot teach stupid people to do clever things
Post #15562 16th Sep 2009 5:48pm
Caterham
do a search on here and you'll find mention of biodiesel else where.
I know that they'll run on much higher percentages than 5% with no percieval difference other than you'll be putting your warranty in jeopardy.
Post #16355 7th Oct 2009 8:52am
_Stingrey_
England 1994 Defender 110 300 Tdi CSW Alaska White
All diesel engines will run problem free on quality B100 fuel.
The reason why manufacturers won't say so is because too many home brewers can't make good enough fuel and hence will not cover it with their warrantee.
Unconverted WVO, water, soap and glycerol content are what cause problems within the fuel systems of the modern common rail engines.
I have manufactured quality biodiesel for the past 6 years and have every batch checked for EN14214 compliance. As a result of these stringent QA tests I have used my Biodiesel in many common rail diesels for a number of years and covered 10's of 1000's of miles. All engines run smoother and deliver improved mpg.
From as little as 10p/litre the time invested in learning how to make EN14214 quality fuel is richly repaid with the added benefit of being greener for the environment.
I haven't paid a penny at the forecourt for 6years and I don't intent to ever have to do so again.
Post #506094 19th Feb 2016 12:41pm
Caterham
very interesting.
do you mind sharing with us your process methods?
out of interest do you run any Euro5 engines on it and do you find any issues?
Post #506097 19th Feb 2016 12:47pm
ericvv
This from my Puma 2.4 handbook
FUEL QUALITY
Note: Land Rover vehicles are capable of
running with up to a 5% blend of bio-diesel, in
accordance with European Standard EN590.
Now, not an issue here, as all diesel in Switzerland remains B0(B zero) to date. Biodiesel has never been approved for road use here.
With very low crude oil prices today, it is more expensive to produce commercial biodiesel for blending (mainly from rapeseed) than to produce mineral diesel. They still blend the roughly 5-7% due to the mandates. The EU taxpayer, and that still includes the UK Whistle , pays the bill. Laughing
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #506106 19th Feb 2016 1:23pm
_Stingrey_
Caterham wrote:
very interesting.
The key to making good Biodiesel is time and understanding of your feedstock.
I use a no titration 2 stage process and always make sure that I achieve 100% clear 10/90 test.
Always water wash until all soaps and glycerol have been removed. (Soap tests done every 2nd wash until all soaps are non detectable). Dry to less than 225ppm and filter to 5um and then settle for 7days before hot centrifuging and ultimately cold filtering to 1um prior to use.
Post #506173 19th Feb 2016 5:09pm
