Home > Puma (Tdci) > 110 sw Puma, Broken tube – but what is it?
Page 2 of 2 <12
Naks
MK wrote:
mine is showing cracks. Bad quality hose.
Is there anything on the Puma that is not bad quality? Rolling with laughter --
Post #150294 14th Jun 2012 10:43am
dgardel
Italy
Yesssss
the driver...... Rolling with laughter Rolling with laughter Rolling with laughter Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #150299 14th Jun 2012 11:07am
Naks
dgardel wrote:
Yesssss the driver...... Rolling with laughter Rolling with laughter Rolling with laughter
True that Thumbs Up --
Post #150300 14th Jun 2012 11:12am
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
I've got one if you want me to post it off - genuine LR part. Drop me a PM. Cheers,
Superspoons
Post #150562 15th Jun 2012 10:46pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
The rubber tube is tube is standard 3/8" tube - should be able to pick it up at any auto factors, only a few pence per metre. If it's perished at the breather end it's probably also perished where it joins the tank so best to replace the whole lot. Connect the new tube to the plastci breather pipe and as others have said stick it up behind the plastic cover out of the way.
Post #150593 16th Jun 2012 9:47am
Page 2 of 2 <12
