![]() | Home > Maintenance & Modifications > air horns |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Those little snail shaped self contained Nautilus horns are good in that they are easy to install and have a reasonable output for their size but they really don't compare to a proper compressed air from a tank driven horn. This is a Grover Stuttertone air horn [as fitted to US firetrucks] running off onboard air on one of my previous Defenders.
The old compressor driven Fiamm two tone hi - lo horns as fitted to fire appliances produce a strident and attention getting sound when fired up together [ie with the rotating valve disc inside the compressor that alternately directs air to each horn removed or if run off a standard air horn compressor]. Steve. Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Must find out where the horn is on the Audi A2 - the current one makes a pathetic "toot" noise. Even my wife is embarrassed to use it.
I could have some fun with an upgrade But shout it at them in German because life is also terrifying and confusing... |
| BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405
Is there enough room to fit a bigger horn in the LR horn space (in a TDCi engine bay), or would I need extension wiring & to fit it elsewhere? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
There's plenty of room behind the headlamps yes but if you are looking to mount a long trumpet type then it gets a bit tight. Steve.
| XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632
Good luck with that. It's on the offside behind the front bumper. From memory you have to remove the headlight just to be able to see it, let alone get at it! Pete |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
Ony one way to go:-
...r_embedded Just waiting on the compressor. |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
The airtank and compressor that the guys in the clip fit is somewhat overkill for the job. The Nathan Airchime (and its UK-licensed equivalent, the Hyson) is actually set up to speak at 10psi, although the volume of air is a bit of an issue. An ARB airlocker compressor and reservoir will work fine for a two-tone Hyson horn (as used for 30 years on BR diesels) as long as you don't want more than about 15 seconds at a time. However being serious for a moment I think it is actually too loud for a vehicle horn; you don't actually want to kill granny with a heart-attack, or shock people into having accidents! |
[quote="blackwolf"][quote="K9F"]
Very true. The one in my clip was a single one of these: http://www.youtube.com/watch?v=c9gYS4dp7ak and was slightly OTT. Steve. Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| 3 Lions Member Since: 11 Jun 2011 Location: Geelong, Victoria Posts: 44
My old D2 only had one low tone horn, high tone was missing, never got around to replacing it. On my Defender I have only found one low tone horn behind the N/S headlight. Nothing behind the O/S light.
The horn is embarrasing, not so much Land Rover Defender, more like Morris Minor I was going to fit the LR high tone but instead now I have fitted a Stebel Nautilus Truck horn. http://www.ebay.com.au/itm/120873351738?ss...1439.l2649 Now I'm happy, just waiting for some t**t to pull out in front of me or cut me up, then he'll be getting a good blast Heeps louder and better, I have had a few sets of triple air horns in the past when I lived in England, but this is great as it just fits in nicely where the original horn should go. Now if I give a split second toot I get the original toot-toot horn, fine if your going past someone you know and want to give a wave, but hold it longer than a nano second and you get the full blast.Fooking loud as Col. 2006 Defender TD5 110. 2012 Trackabout CT. |
| WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748
^^ Wouldnt mind one of those myself. Though Id like it wired up to a seperate switch on the dashboard to reduce accidental use.
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
Would that be a straight swap with the original? ^^^ ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
yep that's how I did mine |
I have a Stebel Nautilus unfitted. How involved is swapping it with the OE one? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
| All times are GMT |
