Home > Maintenance & Modifications > air horns
Page 2 of 3 <123>
Happyoldgit
Maxxed_Ross wrote:
Romadog wrote:
Nautilus air horns are as good , but a lot easier to fit. A number of people on D3 site are fitting these in replacement for standard horns, though wiring should be checked to make sure it is correct.
I had one fitted to my old 101 and 110.
Yup I've had two of these now, one on my old MG ZS and the other on the last 90. Both times it was just a case of swapping the spade connectors over to the new horn.
The hardest part on both was getting to the horn in the first place Laughing
Those little snail shaped self contained Nautilus horns are good in that they are easy to install and have a reasonable output for their size but they really don't compare to a proper compressed air from a tank driven horn. This is a Grover Stuttertone air horn [as fitted to US firetrucks] running off onboard air on one of my previous Defenders.
The old compressor driven Fiamm two tone hi - lo horns as fitted to fire appliances produce a strident and attention getting sound when fired up together [ie with the rotating valve disc inside the compressor that alternately directs air to each horn removed or if run off a standard air horn compressor]. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #149425 9th Jun 2012 9:02pm
ZeDefender
Must find out where the horn is on the Audi A2 - the current one makes a pathetic "toot" noise. Even my wife is embarrassed to use it.
I could have some fun with an upgrade Twisted Evil Tell someone you love them today because life is short.
Post #149431 9th Jun 2012 9:57pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
My Impreza is even worse, it has a very Japaneese sounding "beep beep" effort... it's not even that loud
Post #149438 10th Jun 2012 4:38am
BigWheels
Is there enough room to fit a bigger horn in the LR horn space (in a TDCi engine bay), or would I need extension wiring & to fit it elsewhere? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #149613 10th Jun 2012 8:02pm
Happyoldgit
There's plenty of room behind the headlamps yes but if you are looking to mount a long trumpet type then it gets a bit tight. Steve.
Post #149679 11th Jun 2012 7:26am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Good luck with that. It's on the offside behind the front bumper. From memory you have to remove the headlight just to be able to see it, let alone get at it!
Pete
Post #149685 11th Jun 2012 7:53am
Ony one way to go:-
...r_embedded
Just waiting on the compressor. Laughing
Post #149705 11th Jun 2012 9:26am
K9F
blackwolf wrote:
Ony one way to go:- ...r_embedded Just waiting on the compressor. Laughing
Shocked Maybe so if you really fancy lugging a 12 gallon air tank and quite a sizeable compressor about as well. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #149712 11th Jun 2012 10:57am
The airtank and compressor that the guys in the clip fit is somewhat overkill for the job. The Nathan Airchime (and its UK-licensed equivalent, the Hyson) is actually set up to speak at 10psi, although the volume of air is a bit of an issue. An ARB airlocker compressor and reservoir will work fine for a two-tone Hyson horn (as used for 30 years on BR diesels) as long as you don't want more than about 15 seconds at a time.
However being serious for a moment I think it is actually too loud for a vehicle horn; you don't actually want to kill granny with a heart-attack, or shock people into having accidents!
Post #149723 11th Jun 2012 11:29am
Happyoldgit
[quote="blackwolf"][quote="K9F"]
Very true. The one in my clip was a single one of these:
http://www.youtube.com/watch?v=c9gYS4dp7ak
and was slightly OTT. Steve.
Post #149734 11th Jun 2012 12:38pm
3 Lions
Australia 2006 Defender 110 Td5 SW Chawton White
My old D2 only had one low tone horn, high tone was missing, never got around to replacing it. On my Defender I have only found one low tone horn behind the N/S headlight. Nothing behind the O/S light.
The horn is embarrasing, not so much Land Rover Defender, more like Morris Minor Embarassed
I was going to fit the LR high tone but instead now I have fitted a Stebel Nautilus Truck horn.
http://www.ebay.com.au/itm/120873351738?ss...1439.l2649
Now I'm happy, just waiting for some t**t to pull out in front of me or cut me up, then he'll be getting a good blast Twisted Evil
Heeps louder and better, I have had a few sets of triple air horns in the past when I lived in England, but this is great as it just fits in nicely where the original horn should go. Now if I give a split second toot I get the original toot-toot horn, fine if your going past someone you know and want to give a wave, but hold it longer than a nano second and you get the full blast.Fooking loud as Shocked
Col. Thumbs Up 1979 Series 3 109 FFR (ex Aust Army.)
2006 Defender TD5 110.
2012 Trackabout CT.
Post #198826 4th Jan 2013 4:45am
WarPig
^^ Wouldnt mind one of those myself. Though Id like it wired up to a seperate switch on the dashboard to reduce accidental use.
Post #198951 4th Jan 2013 5:04pm
Would that be a straight swap with the original? ^^^ ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #198953 4th Jan 2013 5:11pm
yep that's how I did mine
Post #198959 4th Jan 2013 5:36pm
BigWheels
I have a Stebel Nautilus unfitted. How involved is swapping it with the OE one? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #199232 5th Jan 2013 6:48pm
Page 2 of 3 <123>
