Home > Maintenance & Modifications > grease nipple knocked off
this may have happened before the weekend but my rear prop is missing a grease nipple... well the shell is there but the stickyout bit has been knocked off ... are these easy to fix ?
Post #148938 6th Jun 2012 8:16pm
Grouse
they usually screw in and screw out. To get the broken bit out tap the pointy end / tang of a file into the hole and screw it out.
Post #148947 6th Jun 2012 8:41pm
cheers Grouse, its just so wet here at the moment, I'll take a look tomorrow, I guess the land rover garage would be able to sell me a few spares ?
Post #148955 6th Jun 2012 8:53pm
Would be cheaper to go to an autofactor place,
edit: Just checked microcat, a standard prop nipple is part # TYL100030 and £1.78
It also shows 234532 @ 52p as well, for the same one Question
(ahh.... the above one is for the main splines, the other os for the UJ itself, so i'd go for the 234532 one)
Post #148959 6th Jun 2012 9:12pm
Grouse
bpman, it might be easier than a visit to a main agent, but I bought a handful from my local Agricultural Engineers, he had an assorted box with different threads and various cranked heads, they cost pennies. Thumbs Up
Post #148965 6th Jun 2012 9:37pm
boxer
United Kingdom 1990 Defender 90 200 Tdi HT Coniston Green
hi bp man if i was you get a set of easy outs, not expensive but are excellent for removing broken stubs etc the problem with using a file is it can spread the nipple if you tap it in to hard.
Post #148969 6th Jun 2012 9:50pm
K9F
Hi Bpman,
Got everything you need in my garage if you fancy a trip down again! Thumbs Up You'll need to bring your own nipples! Shocked Shocked
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #149002 7th Jun 2012 9:45am
noworries4x4
I hope you are going to grease them for him as well Rolling with laughter Rolling with laughter Rolling with laughter If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #149005 7th Jun 2012 9:54am
K9F
Shocked Nutella works for me!!! Rolling with laughter
Off Topic Noworries...any news on you revisiting Green Island? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #149011 7th Jun 2012 10:27am
thanks all, I'll pick some up later today and let you all know how it goes.
Mal - thanks for the kind offer Thumbs Up
Post #149015 7th Jun 2012 11:14am
K9F
You're welcome Steve! Thumbs Up Do you want me to chill the Nutella? Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #149019 7th Jun 2012 11:44am
