![]() | Home > Maintenance & Modifications > grease nipple knocked off |
| Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 535 |
they usually screw in and screw out. To get the broken bit out tap the pointy end / tang of a file into the hole and screw it out.
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
cheers Grouse, its just so wet here at the moment, I'll take a look tomorrow, I guess the land rover garage would be able to sell me a few spares ?
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6205
Would be cheaper to go to an autofactor place,
edit: Just checked microcat, a standard prop nipple is part # TYL100030 and £1.78 It also shows 234532 @ 52p as well, for the same one (ahh.... the above one is for the main splines, the other os for the UJ itself, so i'd go for the 234532 one) |
bpman, it might be easier than a visit to a main agent, but I bought a handful from my local Agricultural Engineers, he had an assorted box with different threads and various cranked heads, they cost pennies.
| boxer Member Since: 12 Jun 2011 Location: north yorkshire Posts: 48
hi bp man if i was you get a set of easy outs, not expensive but are excellent for removing broken stubs etc the problem with using a file is it can spread the nipple if you tap it in to hard.
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Hi Bpman,
Got everything you need in my garage if you fancy a trip down again! Treat every day as if it is your last....one day you will be right!! |
| noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196
I hope you are going to grease them for him as well
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
thanks all, I'll pick some up later today and let you all know how it goes.
Mal - thanks for the kind offer |
You're welcome Steve!
