![]() | Home > Maintenance & Modifications > air horns |
jonny1966 Member Since: 29 May 2011 Location: kent Posts: 87 ![]() ![]() ![]() |
the child in me wants a truck air horn on my puma
any one know where the best place to get a set from ?? |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Hornblasters !!
http://www.hornblasters.com/ Go on the gallery and watch the terror on the streets videos....brilliant ![]() |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 ![]() |
Nautilus air horns are as good , but a lot easier to fit. A number of people on D3 site are fitting these in replacement for standard horns, though wiring should be checked to make sure it is correct.
I had one fitted to my old 101 and 110. http://www.amazon.co.uk/s/?ie=UTF8&key...mt7j05jb_b I also have a large air horn trumpet. T rig this means the need for installation of a compressor and tank. Great if you want to inflate tyres etc, but a lot of hassle just to occasionally only blow a horn. |
This has been done several times before:
http://www.defender2.net/forum/topic11728.html?highlight=horn http://www.defender2.net/forum/topic12077.html?highlight=horn Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
thanks guys
all very helfull |
AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128 ![]() ![]() ![]() |
I just installed that Wolo road warrior 845. Found one for 50USD.
http://www.wolo-mfg.com/truck.htm http://www.ebay.com/itm/Wolo-845-Road-Warr...mp;vxp=mtr Sounds great, but I underestimated the space available under the hood to fit a lenght of 55cm and 16cm diameter. Now it is behind the steering guard. |
did you need an air tank and compressor kit with it? have been looking at the chief horn works out at about £185 with the compressor kit plus postage |
Lukey Boy Member Since: 10 Jun 2011 Location: Norwich Posts: 122 ![]() ![]() ![]() |
Brilliant, I can just imagine the fun I'd have in Norwich (Prince of Wales Rd - Nightclubs) at 2 am on a Saturday/Sunday morning! ![]() ![]() ![]() |
Sounds like Glyn's got the horn! :whistle: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
That one, like some others as well, comes with a direct drive compressor, size like a fist, that was the easy thing to fit next to or rather together with one of the radiator fixings. Just for the horn itself I had to prepare a simple bracket using existing holes in the frame as I did not want to mount the thing visible. |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
As Puma horns are also the anti-theft alarm, the appeal is greater than just noise making for its own sake. Unless accidental triggering of course.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20979 ![]() ![]() |
Very true. Especially if the system is a bit more unique that way you will no that it is YOUR Defender and not another vehicle ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
I think low frequency & high decibels are the answer. Attracts attention & stuns any theif more than the high pitched shreiks & tweets most ignored alarms have. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 ![]() ![]() ![]() |
Yup I've had two of these now, one on my old MG ZS and the other on the last 90. Both times it was just a case of swapping the spade connectors over to the new horn. The hardest part on both was getting to the horn in the first place ![]() |
