Home > Wheels & Tyres > Unusual tyre wear
22900013A
Unusual tyre wear
Regarding the MTRs on my 110, I have noticed that the inner edge of the drivers side front tyre is much more worn than the rest of the tyre. Stratstone Aylesbury checked everything out a month or two ago and said everything was aligned correctly, so what would be causing this problem?
The truck has done 33600 miles now. The other three tyres show normal even wear.
It may be unrelated but I have the impression the vehicle sits down a bit on this corner, and the drivers front wheel looks to be at a different angle to the body (which doesn't mean the body is straight of course...)
Post #148069 1st Jun 2012 10:39am
110SEB
It looks as though some tread blocks are more worn than others. That seems weird since the tyre would wear evenly. Is that the photo distorting things or have you got one dodgy tyre?
Post #148077 1st Jun 2012 11:00am
22900013A
Indeed some are more worn than others. The ones closest to the engine are much more worn than those closest to the body side. The middle ones are the same as the outer ones. As the wear is uneven I can only assume the wheel is somehow misaligned?
Post #148090 1st Jun 2012 11:54am
JWL
Might be worth checking wheel balamce?
Post #148093 1st Jun 2012 12:01pm
22900013A
How do I do that? I know ATS wouldn't touch the wheel alignment.
Post #148094 1st Jun 2012 12:01pm
JWL
Go and have a word with a decent tyre fitters shop, one's that deal with truck or van tyres are usually a bit more ameanable. For the balance, it's when the wheel is off and spun on a machine to check for misbalance, wobble, and they can make it run true by putting the weights on. Might be worth sticking your spare on so that it's easier to drop it on them without the hassle of them taking it off and putting it back on. An offer of a fiver in the folding form for the tea fund works wonders.
Post #148095 1st Jun 2012 12:09pm
22900013A
I was thinking of putting my unused spare on to see if that wears oddly as well, at least way I know its something up with the axle.
Post #148096 1st Jun 2012 12:10pm
22900013A
Okay I took it to the tyre fitters place locally, its not wheel balance, they said that would cause wear across the whole width of the tyre. They were of the opinion that its basically just due to how the steering and axle geometry is set up on a Defender. We noticed the passenger side tyre is similar, although not quite as worn. In fairness the difference inner to middle and outer of the tyre is only fractions of a millimetre but its enough to be seen. Has anyone else run MTRs for this kind of milage, mainly on tarmac? We decided to leave the tyres where they are as to swap them would lead to four unevenly worn tyres rather then just two. When the time comes the back ones can go to the front and it will get a new back pair.
Post #148104 1st Jun 2012 1:00pm
Happyoldgit
TBH as far as I can recall all the Defenders I've had [including the last two Pumas] have suffered some degree of uneven wear to one or both front tyres and that is despite the usual checks on some of them. Steve.
http://forums.lr4x4.com
Post #148110 1st Jun 2012 1:10pm
22900013A
In a way thats...encouraging? Not sure if thats the correct word, but at least its lessens the likelihood of something being amiss elsewhere in the drivetrain.
Post #148118 1st Jun 2012 1:44pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
All the Defenders I have owned have always worn the outside edge of the nearside tyres which I am told is due to the amount of roundabouts locally. My latest 90 I haven't had from new and shod with Cooper ST's which are scalloped on the inner edges. Had everything checked and put it down to the tyres. What did your previous set of tyres wear like?
Post #148177 1st Jun 2012 7:35pm
22900013A
These are the tyres that have been on the vehicle since new.
Post #148178 1st Jun 2012 7:38pm
