Home > Maintenance & Modifications > My new bonnet hinges
Page 2 of 2 <12
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Thanks for the detailed explanation. Bow down LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #146554 23rd May 2012 6:30am
Zagato
I'm still saving up for cup holders Whistle BUT if we can get the price down to 66 Euros I would be in if they prevent bonnet theft. Not having to worry about having your bonnet being nicked would be worth it Wink
1. Zag...
SEE HEAR TO ADD YOU NAME http://www.defender2.net/forum/topic13225.html
Post #146562 23rd May 2012 7:29am
JSG
66 Euros sounds good Thumbs Up John
2011 Tdci 110 CSW XS
Post #146623 23rd May 2012 11:34am
Glynparry25 wrote:
Looks good Thumbs Up
Is it just bolt and nut that goes through to secure it?.... Or have they used some sort of security bit?
Mine can't be removed because of the roll cage so have to remove the 6 nuts/bolts at the moment and wouldn't mind changing it to two. But don't want just allen-head bolts and lock nuts as it will make it easier for a thief.
Glyn Dog Sheep
Security can easily improved by epoxying a ball bearing in the hex socket (or find one that is a tight drive fit), which makes it impossible to drill the head off, and using Loctite and a shearnut instead of the nut. Then pray you don't need to remove your own bonnet, since a die grinder on the shear nut is the only way you'll do it.
Cheap and simple, and a great technique for securing winches (and Puma doors, for than matter).
Post #147011 25th May 2012 12:07pm
ZeDefender
Elegant permanent (!) solution - just bought shear nuts Thumbs Up
Would LR ever need to remove the bonnet (except to replace it) to work on the vehicle? Tell someone you love them today because life is short.
Post #147018 25th May 2012 12:21pm
JSG
Yes, removing the bonnet gives better access for a number of jobs. John
Post #147049 25th May 2012 3:45pm
ZeDefender
Confused
Think I'll just use shear nuts for now then... Tell someone you love them today because life is short.
Post #147050 25th May 2012 3:46pm
AlpenAndes
Austria 2010 Defender 110 Puma 2.4 SW Belize Green
Hi,
can you tell that they are not rattling as they say on their page?
Thanks
Oskar
Post #147057 25th May 2012 4:09pm
ZeDefender
Er - I haven't heard them rattling (over the noise of all the other rattles Laughing )
They are very snug and secure Thumbs Up Tell someone you love them today because life is short.
Post #147064 25th May 2012 5:06pm
Page 2 of 2 <12
