![]() | Home > Td5 > Starting and cutting out issues |
Could be the well known gremlin..........Injector seals and most likely oil in the injector loom and down to the ecu. Pretty much the same symptoms I had a couple of years ago. Not a wallet emptying fix as long as you don't take it to a rob dog garage
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
I would suggest checking the relays under the drivers seat and tighten any terminals that look loose, and keep an eye for any corrosion on them.
Andy |
bmc054 Member Since: 02 Jul 2011 Location: Doncaster Posts: 32 ![]() ![]() |
HI
This happened to me and as mentioned above it was the cable from the fuel relay under the drivers seat which had frayed causing an intermittent fault sometimes my 90 would not travel above 50 mph Bob |
ashfordsv Member Since: 13 Mar 2009 Location: Wicklow Posts: 82 ![]() ![]() ![]() |
Thanks all for your quick replies
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6696 ![]() ![]() ![]() |
Probably both related, and may be a fuelling issue.
Does the tank pump whirr/whine when you switch the ignition on or not? ![]() ![]() |
landyman37 Member Since: 22 Jan 2012 Location: west midlands Posts: 156 ![]() |
When you say it don't start does the glow plug light come on when it will not start ?
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
I had similar issues to this many moons ago on my old td5 after putting a new fuel pump in I replaced fuel lines and all sorts in the end it was all to do with a non return valve stuck open and a bleed valve not working which are both on the top of the fuel filter housing I think there about £50 but if all your other bits that you have been told to look at fail try it
The reason your constantly turning the vehicle other to start is that there is no fuel up at the engine which reverts back to the non return valve Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2671 ![]() ![]() ![]() |
This would be my thought too. Injector seals for the starting issues, and injector loom for the cutting-out issue. If it's injector seals, you may be able to hear bubbles/air in the fuel system during priming. Having the Injector seals done on my TD5 (by my local, and very good indie) was around £200 with VAT. The parts are cheap (part numbers = O rings - ERR7004, Copper washers - ERR6417) but it's a couple of hours labour, and then plus vat... You should be able to check for oil in the ECU yourself... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
Sounds like the Crank Position sensor? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Thanks again for the replys gents!
Typical, the truck drove perfectly all day today, this might happen for a few days ![]() I checked for oil in the wiring loom at the ecu but it's all clean in there. There was no loose wires either. The tank whirrs before start up, however i do remember that it was quiet on the times that i couldn't get it to start! Could this be a fuel pump problem? if not, its either then Injector seals and Injector loom, or Non return valve stuck open and bleed valve not working. Cheers again for the advice ![]() |
If it was quiet when it wouldn't start then it wasn't working. relays under the seat are first call there then.
Agreed, I had the same problem with the TD5 TR and was a slightly loose relay under the driver's seat
![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
As above,
no pump noise = pump not working, electrics under seat Noisy pump = injector seals, as pump circulates aerated fuel, new seals required Normal pump noise = different problem, drink more ![]() Andy Oh and when you having problem, keep an eye on alarm/imobiliser light, may be a cause |
Andrew DefenderBits Member Since: 15 May 2012 Location: Somerset Posts: 43 ![]() ![]() ![]() |
As above, start with the relays, then pull the plug off the ECU and see if there is oil in there and if so flush out with brake cleaner and go from there, if so then change the injector loom to stop any more getting in and re clean once a month until it is no longer oily, next would be fuel pump or crank sensor.
