Home > Td5 > Starting and cutting out issues
ashfordsv
Ireland 2006 Defender 90 Td5 SW Java Black
Can anyone help me with this? after 6 years of trouble free motoring my td5 is acting up a bit! Big Cry I have 2 problems that are probably related to the same fault.
The first is that sometimes it won't start, it may take about 5 minutes of turning it on and off to get it going, after which the engine light will come on for a minute or so. Usually it runs fine but the odd time it stalls.
The second problem is that sometimes it stalls while driving but instead of cutting out and freewheeling, it feels as though the brake is being put on suddenly (Not a comfortable feeling!), the truck usually recovers quickly and the engine light comes on for a minute or 2. After that all is fine again and can stay that way for a few days!
Any advise on this would be much appreciated, cheers.
Post #145442 16th May 2012 11:33pm
JWL
Could be the well known gremlin..........Injector seals and most likely oil in the injector loom and down to the ecu. Pretty much the same symptoms I had a couple of years ago. Not a wallet emptying fix as long as you don't take it to a rob dog garage Whistle
Post #145443 16th May 2012 11:38pm
landy andy
I would suggest checking the relays under the drivers seat and tighten any terminals that look loose, and keep an eye for any corrosion on them.
Andy
Post #145452 17th May 2012 7:17am
bmc054
2002 Defender 90 Td5 HT Tonga Green
HI
This happened to me and as mentioned above it was the cable from the fuel relay under the drivers seat which had frayed causing an intermittent fault sometimes my 90 would not travel above 50 mph
Bob
Post #145453 17th May 2012 7:32am
ashfordsv
Thanks all for your quick replies Thumbs Up i'll start with the wiring under the seat and go from there.
Post #145472 17th May 2012 9:38am
Martin
Site Admin
Probably both related, and may be a fuelling issue.
Does the tank pump whirr/whine when you switch the ignition on or not?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #145482 17th May 2012 10:27am
landyman37
Re: Starting and cutting out issues
When you say it don't start does the glow plug light come on when it will not start ?
Post #145494 17th May 2012 12:19pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I had similar issues to this many moons ago on my old td5 after putting a new fuel pump in I replaced fuel lines and all sorts in the end it was all to do with a non return valve stuck open and a bleed valve not working which are both on the top of the fuel filter housing I think there about £50 but if all your other bits that you have been told to look at fail try it
The reason your constantly turning the vehicle other to start is that there is no fuel up at the engine which reverts back to the non return valve
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #145499 17th May 2012 12:36pm
MartinK
This would be my thought too. Injector seals for the starting issues, and injector loom for the cutting-out issue.
If it's injector seals, you may be able to hear bubbles/air in the fuel system during priming.
Having the Injector seals done on my TD5 (by my local, and very good indie) was around £200 with VAT.
The parts are cheap (part numbers = O rings - ERR7004, Copper washers - ERR6417) but it's a couple of hours labour, and then plus vat...
You should be able to check for oil in the ECU yourself... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #145500 17th May 2012 12:46pm
Naks
Sounds like the Crank Position sensor? --
Post #145503 17th May 2012 12:52pm
ashfordsv
Thanks again for the replys gents!
Typical, the truck drove perfectly all day today, this might happen for a few days Rolling Eyes
I checked for oil in the wiring loom at the ecu but it's all clean in there. There was no loose wires either.
The tank whirrs before start up, however i do remember that it was quiet on the times that i couldn't get it to start! Could this be a fuel pump problem? if not, its either then
Injector seals and Injector loom, or
Non return valve stuck open and bleed valve not working.
Cheers again for the advice Bow down
Post #145667 18th May 2012 1:04am
JWL
If it was quiet when it wouldn't start then it wasn't working. relays under the seat are first call there then.
Post #145668 18th May 2012 1:10am
JSG
Agreed, I had the same problem with the TD5 TR and was a slightly loose relay under the driver's seat Thumbs Up John
2011 Tdci 110 CSW XS
Post #145679 18th May 2012 7:24am
landy andy
As above,
no pump noise = pump not working, electrics under seat
Noisy pump = injector seals, as pump circulates aerated fuel, new seals required
Normal pump noise = different problem, drink more Whistle
Andy
Oh and when you having problem, keep an eye on alarm/imobiliser light, may be a cause
Post #145680 18th May 2012 7:37am
Andrew DefenderBits
United Kingdom 2003 Defender 110 Td5 HT Alpine White
As above, start with the relays, then pull the plug off the ECU and see if there is oil in there and if so flush out with brake cleaner and go from there, if so then change the injector loom to stop any more getting in and re clean once a month until it is no longer oily, next would be fuel pump or crank sensor.
Post #145729 18th May 2012 12:23pm
