![]() | Home > Maintenance & Modifications > Has anyone used a plug-in tuning module instead of a remap ? |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
I just wondered because I have a module from these guys for my last motor (£150 but never used it)
http://tuning-diesels.com/index.htm This firm's products were highly recommended by Practical Mechanics magazine. If I remember correctly it works by by passing the MAP sensor, takes 10 mins to fit and gives better fuel consumption and more low rev grunt. I am aware that there are loads of these things about but this one in particular was singled out as the best. There's no doubt that Alive and BAS are the Rolls-Royce of remapping/performance enhancement but I wondered if a similar result might be acheived for a smaller outlay Anyone used one ? Did it work ? |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 277 ![]() ![]() ![]() |
I had a DasTek plug-in on my Discovery. Already fiited to my Defender, when I bought it, was a Steinbauer plug-in.
Got rid of the Steinbauer in favour of a 'proper' tune from BAS. I think that says it all.... Tony |
The TR 90 had a Dastek plug in fitted when I bought it and it worked well, gave a lot more mid range without the TD5 lag and worked even better with the transfer box upgrade fitted. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
plug-in chips are not worth it. All they do is basically fool the ECU into overfuelling.
Get a proper remap from BAS/Alive, etc. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
