Home > Maintenance & Modifications > Has anyone used a plug-in tuning module instead of a remap ?
rossy
I just wondered because I have a module from these guys for my last motor (£150 but never used it)
http://tuning-diesels.com/index.htm
This firm's products were highly recommended by Practical Mechanics magazine. If I remember correctly it works by by passing the MAP sensor, takes 10 mins to fit and gives better fuel consumption and more low rev grunt. I am aware that there are loads of these things about but this one in particular was singled out as the best.
There's no doubt that Alive and BAS are the Rolls-Royce of remapping/performance enhancement but I wondered if a similar result might be acheived for a smaller outlay
Anyone used one ? Did it work ?
Post #145175 15th May 2012 7:53pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
I had a plug in box on my TD5 when I bought it. It went well enough when you were giving it lots of throttle a massive surge of power, (well relative to standard) but not very driveable in normal situations. In fact I unplugged it and prefered driving it without it. I then got an IRB/BAS stage 1 tune, that made the LR far more driveable. My advise would be spend the money on a remap.
Post #145209 15th May 2012 9:53pm
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
I had a DasTek plug-in on my Discovery. Already fiited to my Defender, when I bought it, was a Steinbauer plug-in.
Got rid of the Steinbauer in favour of a 'proper' tune from BAS. I think that says it all....
Tony
Post #145247 16th May 2012 7:39am
JSG
The TR 90 had a Dastek plug in fitted when I bought it and it worked well, gave a lot more mid range without the TD5 lag and worked even better with the transfer box upgrade fitted. John
2011 Tdci 110 CSW XS
Post #145249 16th May 2012 8:06am
Naks
plug-in chips are not worth it. All they do is basically fool the ECU into overfuelling.
Get a proper remap from BAS/Alive, etc. --
Post #145272 16th May 2012 9:35am
