Home > Puma (Tdci) > Scangauge to kill EGR MIL?
ZeDefender
Just "freefalling" here, so apologies if this is a stupid question...
If I just unplug the EGR, I get a MIL after a few cycles. I read somewhere that you can use Scangauge to get rid of the light permanently. Is this correct and which Scangauge would I need?
Matt
p.s. I'm just experimenting, Gary - I'm still using your remaps as well Thumbs Up Tell someone you love them today because life is short.
Post #144584 11th May 2012 11:21pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
have you not got the egr removal on your remap ??
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #144588 12th May 2012 1:45am
ZeDefender
Yes but Gary (Alive) has rigged my final remaps so the EGR wakes up and self-cleans when switching off. I had some problems yesterday with heat and power loss (even with the remaps) and I'm looking at several possible causes (sticking EGR, grubby/busted MAF, CHT cooked with engine blanket etc.)
I have a long trip coming up and the nearest dealer (I trust) is a long way away and can't look at the car for 2 weeks Sad
Plus I'm just curious about what Scangauge can do Smile Tell someone you love them today because life is short.
Post #144590 12th May 2012 6:54am
Lorryman100
Most/All diagnostic tools will reset the MIL light but if the EGR remains unplugged the MIL will illuminate again as the EGR has failed the test cycle because it is unplugged. The only way to permanently have the MIL switched off when the EGR is unplugged is to do so through rewriting the EMS software as Gary has done for you with the remap file.
Have a read of this post as it may be worthwhile getting this mod from Gary:
http://www.defender2.net/forum/topic10564.html?highlight=egr+oem
Scangauge here:
http://www.defender2.net/forum/topic10829.html
Lorryman100 wrote:
I'm with K9F on the scangauge 2. Pound for pound it is a very handy and versatile tool all packaged up nicely and easily blends in with the dash. The scangauge 2 allows you to clear dtc's (tested) which illuminate the MIL lamp and the new software versions also allow you to display pending dtc's (untested) as well. The standard gauges cover most of the engine monitoring systems and those that are not covered can be programmed into x gauge, an additional set of codecs for sensors on the Ford PWM and CANSF protocols. The standard gauges show, Manifold Absolute Pressure/Boost, Miles Per Gallon, Kilometres Per Gallon, Miles Per Litre, Liters Per 100Km, Kilometres Per Litre, Miles Per Hour, Kilometres Per Hour, Revolutions Per Minute, Throttle Position Sensor, Water Temperature, Average Fuel Economy, Trip Fuel Cost, Cost Per Mile, Battery Voltage, Intake Air Temperature, Gallons Per Hour, Litres Per Hour, Engine Loading, etc.
The additional xgauge codecs available give you BHP, EGR duty cycle, FPr, CHT, Fuel pump duty cycle, Barometric pressure, fuel tank level in %, Fuel pump pulse widths etc.
The scangauge e is suited more to the eco friendly minded driver as it is designed more for eco driving, giving info on real time fuel use and your real time carbon footprint, so not really applicable to a defender which has the aerodynamics of a 3 bed semi on wheels and the fuel usage which mirrors this fact. It also does not give you access to as many gauges as the scangauge 2 and does not allow you to read and clear faults, or has the x gauge function.
Just my tuppence worth.
Brian.
Post #144624 12th May 2012 5:56pm
ZeDefender
Cheers Brian Thumbs Up
I actually already have a "EGR closed only" remap from Gary (he has excelled himself with customer support Bow down ) but I have also been looking at all sorts of possibilities to just delimit the speed (I have a Matzker device) and kill the EGR without any software mods, one reason being my 110 had "judder issues" with almost all remaps. These however seem to have resolved themselves in some weird way after an engine fault Shocked
I'm posting it separately as it covers several issues. I would be interested to know what you think...
Matt Tell someone you love them today because life is short.
Post #144650 12th May 2012 8:08pm
Lorryman100
The Matzker device is an external software mod. It still does the same thing as a remapped file only more expensive than getting a OEM fuel file with the EGR closed from Alive. The EMS is programmed with parameters for the operation of the EGR and the only way to have the EGR bypassed without showing the MIL is by software. Or mechanically you could blank either end of the EGR and it will operate as normal without allowing the exhaust gases to be recirculated back into the inlet manifold as it will still be plugged in as far as the EMS is concerned. Thumbs Up
Post #144654 12th May 2012 8:23pm
ZeDefender
Indeed (silly me) - I actually bought it with the 110 from new (with a load of other Matzker goodies) and never sold it as I could never get the 600 quid Shocked back. Very nice device though - my kind of thing Laughing Tell someone you love them today because life is short.
Post #144663 12th May 2012 9:07pm
ZeDefender
Wouldn't mechanically blanking the EGR cause a MIL? Tell someone you love them today because life is short.
Post #144668 12th May 2012 9:27pm
Lorryman100
Have a look at the posts from Denis Thumbs Up
http://www.defender2.net/forum/topic12250.html
Post #144671 12th May 2012 9:59pm
ZeDefender
Thumbs Up Thumbs Up Thumbs Up Tell someone you love them today because life is short.
Post #144678 12th May 2012 10:20pm
copey28
Scotland 2003 Defender 90 Td5 HT Chawton White
having trouble with my defender can someone tell me what mil means Mr. Green
Post #144958 14th May 2012 6:50pm
ZeDefender
Malfunction Indicator Lamp - just in case you didn't realise your engine was bug*ered when it stopped Laughing Tell someone you love them today because life is short.
Post #144968 14th May 2012 7:32pm
copey28
cheers my engine managment light has came on and aint going off and blue smoke has started when i start it up in the morning any ideas?????????????????? Big Cry
Post #144985 14th May 2012 9:00pm
ZeDefender
Not an expert - perhaps a good idea to start your own thread as something like "Help! Blue smoke and warning light on"
Should get you some expert attention Thumbs Up Tell someone you love them today because life is short.
Post #144991 14th May 2012 9:10pm
Lorryman100
@copey28, I should be down your way on Friday or Saturday taking the dogs to the beach. Drop me a pm if you want to meet up and I will bring a diagnostic tool with me, unless of course the one you ordered arrives and you have it fixed by then. Whistle Thumbs Up
Brian.
Post #145010 14th May 2012 10:29pm
